Results 1 to 10 of 10
Thread: when should i open my pool
    careingemt's Avatar
    Sep 2013
    PA
    143
    Hi everyone,
    I am a bran new pool owner. I live in Pittsburgh Pa. I own an above ground pool that is 52'' high and 18' across. It has a cartridge filter and a propane heater ( Hayward ).
    My pool was installed on August 12, 2013 so I only got to use it about one month. My pool has a black cover that does not allow water to seep through, I am guessing
    it does not allow sunlight through. I hear this is a good thing but I am getting tired of having to pump off the water. I am dying to open my pool for the first full summer.
    any thoughts as to when the best time is to open my pool. It is a chlorine system. Any help with pool maintenance, terminology etc. (what is meant by a salt system) would be much appreciated.
    Thanks for your input
    Fran
    AG 18 feet accross 52" high pool wall 7000 gallons .... pool math = 7600
    Hayward extreme cartridge filter 100sq feet
    pool is heated by propane Hayward heater
    pool installed aug 12 2013
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: when should i open my pool
    The recommendation is to open before the pool water temp rises above 60. As long as you wait until the air temperatures get above freezing, you can pretty much open whenever you want.
    As to your other questions, you're best served by heading over to Pool School, the link is in the upper right corner of every page.
    Wares Pool Service's Avatar
    Apr 2014
    Austin, TX
    5
    I agree. Get all the information you can before starting any process when it comes to your pool. As for the time to open it doesn't really matter. I have pools on service that want opened in feb-march just so its there and ready to be used.
    Apr 2014
    Pittsburgh
    11
    Hi Fran! I'm also in Pittsburgh, and a first-time pool owner. So excited to get this season going and get my butt in the pool!
    Casey's Avatar
    SW PA
    10,438
    Fran, I am also very close to the Burgh and I just took the cover off my pool yesterday. I have a little bit of work to do but will be topping her off and starting the pump soon.
    Read Pool School. You will learn so much!
    shaffe43's Avatar
    Mar 2014
    Pittsburgh
    52
    Ha I am am from pittsburgh as well. Just started the TFPM! this will be the first season.
    Lots of yinzers around
    In Ground 35k Gallon
    36 Sq Ft Nautilus NS DE Filter
    Location Pittsburgh PA
    Aquabot Turbo T2 Cleaner
    Vinyl Liner (new in 2016)
    A salt water system is based on using a SWCG (Salt Water Chlorine Generator). This is a device attached to your return plumbing that uses electricity to convert salt to chlorine. Salt is added to the pool water making it "salt water." Then the SWCG turns it in to chlorine instead of having to add liquid chlorine yourself.
    I'm about to start checking my water temp, it's probably in the 40s right now. Most likely I will open at 55.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Sep 2012
    Pittsburgh
    35
    I also live in Pittsburgh and have an inground fiberglass pool . I will be opening it this weekend . you should keep the water circulating on the nights coming up that will be at or below 32 and watch for freezing in your pipes.if you have a gas heater as compared to a heat pump you will be able to heat the water to swimming temps on many days in April and May here . The night will cool it down quite a bit. I use ppg sustain chemicals system and am happy with that . Have fun
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    I'm just next door in Ohio. Opened my pool and hooked everything up yesterday and today. It was 81 degrees today but is supposed to be 28 Tuesday. So I'll be sure to keep that pump running. Now that it is ready to go I just need that water to warm up!!!
    27' Round X 54" Aqua Leader Sentinelle AGP, Vinyl J hook liner. 18,500 gal.
    Waterway 19" oval sand filter, US Motors EZBN25 1.0 hp 1.5 SPL Pump, BBB (Empty Aqua Smarte System connected, may use during vacation), Barracuda Zodiac 1500,
    Taylor FAS-DPD K-2006 Test Kit.
    Casey's Avatar
    SW PA
    10,438
    Quote Originally Posted by shaffe43 View Post
    Yinz stick around and read Pool School!
