Results 1 to 9 of 9
Thread: Raising PH and keeping TA steady
    I added CYA and my PH dropped to 7.0. My TA is exactly where I want it at 75 (had it at 100 last year and was continually battling rising PH...this year have never added acid). So now I want to raise PH. What's the better way to do it if I don't want the TA to move: add borax or aerate? Thanks in advance.
    30' AGP 2hp haywardpump 25'' sand filter,permasalt system
    Jul 2007
    Waterford Michigan
    36
    Re: Raising PH and keeping TA steady
    Airation is slow but free.
    15x30 AG
    Cartridge Filter
    Solar Heater
    1.0 HP 2 Speed pump
    + 2 KIDS
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    I agree with dbrown! FREE is good Turn one of retun jets up towards the surface of the water so it breaks the surface and just walk away. In a few days I would test it and see how much it rose.
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I wouldn't wait a few days....test it daily just to be sure.
    Thanks. Since I didn't get a reply early last night, I went with the aeration method. Will test tonight to see if there's a change.
    Thanks again.
    Quote Originally Posted by Charrua
    Chemgeek just posted this in another thread-
    Borax is used for TWO distinct uses. One is to raise the pH without as much rise in TA. It does raise the TA, but only half as much as using pH Up / soda ash / sodium carbonate. Only aeration raises the pH with no change in TA.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    The reason I said to check in a few days was because aeration is a slow process and with your PH now at 7.0 I doubt its going to rise that much overnight.
    Les
    Helpful Links:
    I'm happy to report that the aeration method worked better than expected. PH was 7.4 the next day. Aeration was accomplished by pointing the two eyeballs upwards.
    11,969
    EXCELLENT!
