Thread: Returns making bubbling sound
    Hello,
    I have a built in floor cleaning system (paramount) and last two days returns started making bubbling noise. When the cleaning heads starts, bubbles coming in from that too. I can't find any leaks or anything. Is it something i should worry about? Anyone seen this before?
    Regards,
    Ani, Phoenix AZ
    12888 gallons free form (3'-5'-4') Pebble Sheen Inground
    Jandy ePump, 460 Sq ft Catridge filter
    In Floor cleaning system - Clear O3
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Returns making bubbling sound
    Sounds like you are getting air from somewhere, and you shouldn't be seeing that.
    Essential Links:
    30,419
    Pump running, air will only get into the system from the suction side of the system.
    There is an article in Pool School on Suction Side Air Leaks.
    First check all the easy things, be sure that the pool level is not too low. Then look at skimmers, either very full of debris, or perhaps a door blocked partway, either of which will cause skimmer to suck air. (I had a pine cone keep one skimmer door nearly shut and that skimmer was sucking air.)
    Then look at all the harder to fix things.
    Thank you for your suggestions. I found the article for leaks. Will check once I get back home today
    Regards,
    Ani, Phoenix AZ
