Results 1 to 8 of 8
Thread: I need Help! I am out of practice!
    May 2013
    Jonesville, VA
    28
    Hello all after winter break! I may have messed up my pool.
    I did not cover it this fall and winter so I have a bunch of leaves in the bottom. I have been dipping them out and nearly have them all. We got the pump hooked back up today and started shocking to get rid of the green water.
    Two people adding bleach without each others knowledge is why the FC is so high.
    So here are my first numbers: FC- 45 , ph- way above 8.2(the color is bright fushia), TA- 50, CC-4
    I did not do a calcium hardness or CYA test yet. How in the world do I get the ph down? I have added a full container of ph down powder and 16 oz of liquid muriatic acid. I checked the ph before the chemicals and about an hour after adding it.
    Forgot to add the water temp is 60.
    Intex 24'x52" Ultra Frame AG, 12,481 gal.,
    Krystal Clear Model 633t pump, 2,500 GPH, 1/2 HP
    Install 5-17-2013
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: I need Help! I am out of practice!
    If you took the PH test with FC levels above 10 your not going to get an accurate test. It will read a false high. Nothing you can do about the PH with FC levels above 10.
    If you did not test for CYA how did you know what your SLAM level was ?
    Jeff
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,015
    You ignore the pH during the SLAM. When FC is above 10, the results are probably wrong.
    http://www.troublefreepool.com/conte...tain-shockingl even mentions it under prerequisites.
    May 2013
    Jonesville, VA
    28
    The sun was not bright enough for a good CYA test and I just wanted to get some chlorine in the water. I am in the process of adding water so I did not think it wise to start a full shock cycle until all water is in, leaves are out, and proper numbers run. The ph just really freaked me out.
    I said I am out of practice. Got some reading to do tonight!
    Install 5-17-2013
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yes do some reading. I'm sure you have plenty of FC and ignore the PH. Get a CYA level and then set your SLAM level to that. The FC will come down own it's own.
    Jeff
    May 2013
    Jonesville, VA
    28
    Do I need to do anything about the TA? Pool Calculator says add baking soda.
    Install 5-17-2013
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Not now. Get the pool cleared up and the SLAM process done and then we can take a look at that if it needs attention.
    Jeff
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    +1 to pwrstrk...
    Don't worry about TA now at all, just focus on Cya and FC/SLAM.
    Essential Links:
