Thread: Pro-Clor what should I set Pool Calc to?
    Southern Indiana
    229
    Hey folks... I wound up with 5 cases of Pro-Clor Liquid Chlorinator today (long story)... I am opening the pool this weekend.. Is it still bleach? I know this sucks... but I have 5 cases to work with.
    Guessing I calculate it for 12.5 bleach?
    shows:
    sodium Hypochlorite 12.5
    inert ingredients 87.5
    thanks for any help.
    I want to get it to shock level today so I can burn off any junk from the winter months... so will be using the TF-100 kit to get me in good shape.
    Pool 16 x 33.5 Foxx Pool with rounded corners 3.5 at each end and 5+ in the middle (16000 GAL)
    Equipment - 300 LB Hayward filter with a Pentair SuperFlo pump (3/4 HP). Also Hayward H series Heater and a dedicated jet for a Polaris 280 with a booster pump (3/4HP). Hayward Chlorinator CL200.
    Pool has Main Drain, 2 return Jets with 1 inch eyeballs, a skimmer with floating weir, and the dedicated Polaris jet. Also has a valve for the Waterslide.
    30,414
    Re: Pro-Clor what should I set Pool Calc to?
    If it's more than 30 days old, I think I would use 10% as a ballpark strength......less than 30 days, 12.5% makes sense to me.
    38,267
    Yes it is the same stuff as bleach, just should be stronger. But as Dave pointed out, it may have lost some of that strength depending on age and how it was stored.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    As is mentioned above, the stronger the liquid chlorine / bleach, the quicker it looses its potency, heat speeds the process, this is why it is alway best to keep your bleach / liquid chlorine in a cool location. It is also why you should avoid buying liquid chlorine from places that don't have rapid turn over of their inventory and / or store it outdoors. Big box stores with their pool supplies in the outdoor garden centers are a prime example of this.
    Ike
    Southern Indiana
    229
    Thanks guys...
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It may not be a bad thing since you are going into SLAM mode.
    Essential Links:
