Results 1 to 10 of 10
Thread: Pump pressure help!!
    Jan 2014
    Texas
    14
    Just back washed then rinsed. When I turned it back to filtration my gauge and pressure are jumping back and forth between 0 psi and 18 psi. It keeps bouncing back and forth every 30 seconds or so and bubbles are coming from the return jets. Help?????
    Jane in Northeast Texas
    18 x 36 Inground Vinyl Liner, 20,000 gallons, Hayward Pro Series 24" 300 lb top mount Sand Filter, Hayward Super II 1 hp pump, 1 skimmer, 2 inlets, 2 Deck Jets, Vinyl Covered Stairs, Polaris 280 Cleaner
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Pump pressure help!!
    Probably a bad gauge. Any idea when it was last replaced?
    Not sure I can help with the bubbles, though.
    Jan 2014
    Texas
    14
    It's brand new!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    It sounds to me like your pump is loosing prime, did you clean the pump strainer basket while it was off? If so did you lubricate the basket o-ring with silicone lubricant before sealing it back up and check for debris (twigs, etc.) around the fitting?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    How does the pump basket look? Is it full of water?
    Generally, air bubbles indicate a suction side leak, however, it could be you inadvertently got some air into your filter, and it's not bleeding out properly.
    Jan 2014
    Texas
    14
    I will try these suggestions this afternoon when we get home! Thanks much! Stay tuned please!!
    30,402
    Confirming what others have said, you are loosing prime. Either a suction side leak or perhaps because your pool water level is too low and you are sucking in air at the skimmer.
    Jun 2013
    SpringHill FL
    415
    Check the water level also. Sounds like it may be sucking air from skimmer if its got presure then no presure
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    Jan 2014
    Texas
    14
    Hi everyone, thanks so much for your tips. We cleaned pump basket and stuck hands in pipe to clear. Added more water before closing pump. Wasted out a lot of rainwater and then back washed again. All seems to be running fine now!! Thanks for all of your responses and advice!!!!
    Apr 2014
    USA
    4
    Quote Originally Posted by FamilyGuy View Post
    Yes, I had this problem exactly! I wish I found these forums sooner.
