Thread: DIY automatic chlorinator.
    Aug 2011
    Cochranville, PA
    228
    I was wondering if anyone has made one? I had a thought if you were to place a small hose in front of the return would that create the vacuum to pull the liquid out of a container. You could use a ball valve to dial in the proper amount. Or maybe plumb in a T after the pump with a check valve.
    1) The size of your pool in gallons 4440.
    2) The type filter you have is an Intex 28651EG Krystal Clear 3000 GPH sand filter
    3) If your pool is an AG (above ground)
    4) Intex 15 by 48 metal frame.
    Southeastern, Pennsylvania.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: DIY automatic chlorinator.
    Take a look at this thread. 😎
    http://www.troublefreepool.com/showpost.php?p=543664
    Jeff
    Aug 2011
    Cochranville, PA
    228
    Quote Originally Posted by pwrstrk View Post
    Take a look at this thread. ��
    Thanks. I like how the tube was stuck in the skimmer. We shall give it a go this season.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Keep us posted on how it turns out for ya. 😎
    Jeff
    mas985's Avatar
    Pleasanton, CA
    11,737
    Here is one I did that can be used for either Acid or Chlorine: http://www.troublefreepool.com/threa...jection-System
    Mark
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    OMG I'm so going to do this... I've just found a nice little peristaltic pump and I'm gonna start designing.... So excited.... You've just saved me nearly $400 to get a liquidator shipped all the way to Australia from the US.... So thank you....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
