Thread: Cracked gunnite step in vinyl pool
    Apr 2014
    Maryville, TN
    1
    Hello,
    New member. My name is David. I have a follow-up question to this thread, as it concerns gunite.
    First off my pool is a 25+ year old, 20'x40' In-ground, Grecian-style, vinyl-lined pool with gunite steps (photo). The gunite has some kind of chalky plaster on top of it. This winter it developed a crack in the side wall of the steps (photo). I used an epoxy to stop the leak (2"/day) but realize that it is only temporary and is already starting to peel off. A local pool company recommended a guy with a company called Perma Ceram. He said the pool needs to be drained to below step level. He then will grind off the finish over the gunite, seal the leak and reapply a finish over the entire step surface.
    Just wondering if this sounds right or if you recommend another process. Said the cost will be $800-$1000 and should take a day to day and a half.
    Appreciate any feedback and have already bought some recommended products this morning from this site (Taylor Chloride Salt Water Drop Test Kit K-1766, and TFTestkits TF-100)
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Cracked gunnite step in vinyl pool
    That sounds like a proper repair to me, and not an unreasonable cost.
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    Don't drain the pool too low or the vinyl liner can get messed up.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
