Thread: Algae?
    Algae?
    I don't know if this is algae or not; hoping someone could help. I have vacuumed the pool every other day for the past week and the following keeps showing up on the bottom of the pool in the same spots.
    I have put in algaecide; and kept my chlorine level up to 10ppm for the last 10 days. my total alkalinity is 120, and ph is 6.2, stabilizer is 35.
    Any help with this would be greatly appreciated
    [attachment=0:q4wuno5b]pool.jpg[/attachment:q4wuno5b]
    20k gal, vinyl, Sta-rite 1 HP Dyna-Glas pump, Sta-rite System 3 300 Sq ft. Cartridge Filter
    Re: Algae?
    That doesn't really look like algae to me, though it is difficult to be sure. It looks like drifts of blown in dust to me.
    If your PH is really 6.2, you need to raise it up to at least 7.0 right away. However, most PH tests won't indicate numbers lower than 6.8 so I wonder if that is perhaps a typo?
    Re: Algae?
    Yes I am sorry it was a typo 6.8
    Re: Algae?
    Good, 6.8 is better than 6.2. You should still raise it to 7.0 as soon as possible. Your TA level is good, so borax is probably the best choice for raising the PH, but if you have soda ash, PH Increaser, etc you can use one them instead.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Algae?
    I have toe-indents in the bottom of my pool and the dirt/dust whatever settle in those low places.
