Thread: Need Help! Pool out of bottom track
    Apr 2014
    Chicago, IL
    3
    Over the winter the uprights heaved, and as a result, the wall came out of the bottom track. It is over a 10' span. The uprights have also come loose. The rest of the pool is fine.
    How bad is this, and will it collapse?
    Casey's Avatar
    SW PA
    10,448
    Re: Need Help! Pool out of bottom track
    More than likely, it sounds like you will need to have the pool reinstalled. I'd also double check on the levelness. Do you have any pics? Is there a deck around the pool?
    Welcome to the forum.
    Apr 2014
    Chicago, IL
    3
    it is level aside from the post that heaved.
    what am i looking at in terms of cost?
    i will post pics tomorrow.
    thanks!
    Casey's Avatar
    SW PA
    10,448
    I have no idea. You need to call around and get prices from pool installers or you can do it yourself.
    Also, it would help if you filled out your profile on location and add your pool specs to your signature so we don't have to guess your climate and what you're swimming in.
    Apr 2014
    Chicago, IL
    3
    Quote Originally Posted by Casey View Post
    Thanks I will.
    What is odd is that the wall came out of the track and moved to the inside. Also, the it came out of the track under the deck. fwiw the deck didn't move the pool.
    24' AG aqua leader pool with a deck around 1/4 of the pool
    Casey's Avatar
    SW PA
    10,448
    The pool needs reinstalled. You can DIY with a few friends and family or pay someone to do it. Good luck and keep us posted!
