I was afraid of coming home to a green pool-- well , it wasn't green, but yellow from all the pine pollen floating on the top and some leaves on the bottom. Sometime during the week I was gone, the filter pump and maybe the cleaner boost pump stopped working with the resulting no flow lights on the SWCG box. So, I tried to start the filter pump got a clunk sound and nothing else--same with the boost pump that tried to start the filter pump. I removed power from from the timer and went back out to the timer after resetting the CB. This time I got a hummmm from both the filter and boost pump. My skimmers were both full of leaves sucked down to the bottom of the baskets. I'm assuming this may be part of the problem, but the main drain was not cluttered with any debris. So, I would think the pumps were getting sufficient water; but I've thought wrong before. Any suggestions/ comments are going to be appreciated!
