Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: How to add CYA?
    Jul 2012
    Saugerties, NY
    447
    How to add CYA?
    Please always start your own thread, thanks. Butterfly
    Don't mean to hijack the thread, but is there a reason for adding CYA through a sock hanging in front of a return? I've always poured it into a skimmer slowly.
    TreeFiter
    Pool Technician
    Saugerties, NY
    Dec 2009
    Chandler, AZ
    84
    Re: Liquid Stabilizer vs Dry
    I have in floor cleaners. I just broadcast stabilizer over the whole pool while the pump is running and it disperses fairly quickly.
    13000 Gallon Shasta Pool In Ground 2004
    Gunite/PebbleTech, AutoPilot Salt Water, Cartridge Filters, Ozone, In Floor Cleaner.
    Jan 2013
    Houston, TX
    1,079
    Quote Originally Posted by TreeFiter View Post
    Keeps it from staining the pool surface.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    If you do it that way it gets hung up in the filter and takes longer to dissolve. Could also get back washed out. The sock method is the preferred method. 😎
    Jeff
    Quote Originally Posted by Copperhead View Post
    I would advise against broadcasting cyanuric acid. It does not dissolve quickly enough.
    Support the site
    Mar 2012
    Richmond, VA
    24
    Re: How to add CYA?
    Just added 4lbs through some panty hose in the skimmers and it took about 4 hours. Just a little massaging the hose to get it all dissolved.
    Richmond, VA
    36,000 Gal/20'x40' Vinyl Diving Pool - Inground/Hayward Tri-Star Dual Speed 1.5 HP Pump/Hayward T-15 Salt Cell/Goldline Controller/Sand Filter/Borates
    Apr 2014
    south fl
    14
    Re: How to add CYA?
    I usually just add some pucks to the floater when the CYA is low but on the few occasions I added it from the bag, I just slowly poured it into the skimmer. I have a cartridge filter and have never had any issues dosing it this way. I would be reluctant to simply broadcast it because it does not seem to dissolve too well and I would worry that it would sit on the bottom and bleach/stain the surface.
    Supposedly you don't want to rinse you filter for a couple days after you add CYA (because it takes a while to dissolve) so if you're due for a filter cleaning then do that first.
    38,284
    Re: How to add CYA?
    We have also seen a couple of reports where it appears that the CYA poured into the skimmer ended up clumping and clogging the pipe. Using a sock is safer.
    Dec 2009
    Chandler, AZ
    84
    Quote Originally Posted by JamesW View Post
    Just added 8 lbs. this way and it was gone in an hour.
    You have in-floor cleaners, which keep the acid from sitting on the floor. However, most people do not have in-floor cleaners.
    In any case, I don't think that broadcasting cyanuric acid is a good method. I don't think that it is a method that should be presented as an acceptable option.
    Support the site
    Jul 2012
    Georgia
    77
    I broadcast the CYA once, and my Polaris collected it all in its little bag. Poor thing was so heavy it was falling over on its side.
    Now I get the more expensive liquid CYA.
    19k gal, STS1072R A.O. Smith C-Face Motor .75HP Full-Rated 2-Speed, Hayward Sand Filter
    38,284
    Quote Originally Posted by LotusRacerX View Post
    Why? Seems like a waste of money when an old sock in the skimmer or in front of a return jet would work fine.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    The granular stabilizer is just as good and cheaper. You have to add it the right way. The sock, knee high method in front of a return is the preferred method.
    Jeff
    Dec 2009
    Chandler, AZ
    84
    Re: How to add CYA?
    What color staining am I watching for?
    38,284
    Re: How to add CYA?
    It is an acid, so it could fade the pool surface.
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    Re: How to add CYA?
    You should not run the Polaris after you put in the CYA. Just like you shouldn't backwash a filter. Give it a week to dissolve.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    Re: How to add CYA?
    I will note that different brands of CYA dissolve differently. I found the brand from Walmart, HTH, was super fast to dissolve. In comparison the brand from the pool store (name not recalled) was super hard and took quite a long time to dissolve. The HTH was almost fluffy compared to the hard rocks of slower dissolving sort.
    Re: How to add CYA?
    Quote Originally Posted by sargent View Post
    There is no reason not to run the Polaris when adding cyanuric acid.
    Support the site
    Jul 2012
    Saugerties, NY
    447
    Re: How to add CYA?
    Quote Originally Posted by anonapersona View Post
    Was there a difference in the size of the granules?
    TreeFiter
    Pool Technician
    Saugerties, NY
  20. Back To Top    #20
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    How to add CYA?
    I've had the same experience. If I recall correctly, the Walmart HTH brand seemed to be more "flake like", for lack of a better term.
    Jeff
