Results 1 to 8 of 8
Thread: Pool startup. Saltwater
    Mar 2014
    Chesapeake, VA
    74
    How is an easy way to bring up ph in a saltwater pool
    Dave Graham
    6,000 Gallon 16' x 4' Intex Round Ultra Frame
    Hayward S244-T Sand Filter, Intex SWG, Hayward SF1593 1.5hp Pump, Hayward Thru-Wall Skimmer
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Pool startup. Saltwater
    Borax or soda ash.
    It is very uncommon to ever need to raise the PH when using a SWG, as the SWG tends to raise PH on it's own.
    Can you post a full set of test readings?
    Support the site
    Feb 2012
    Maryland
    400
    Quote Originally Posted by JasonLion View Post
    Ditto this. I have never had to raise PH, I lower PH to lower alkalinity and am hopeful this year to get it under control and have more stable PH.
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    Aerate. I am doing this right now on my SWG pool. But that is because I added muriatic acid to bring down the TA, which also lowered the pH, and I want the pH to rise quicker than it would with just the effect of the SWG.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Quote Originally Posted by sargent View Post
    Your trying to lower TA right ?
    Jeff
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    I'm trying to get TA down, and then I want to add Borates. At this time of year I'm not generating all that much chlorine, so it would take several days to get much movement upward in pH. I guess I'm just a little impatient.
    My point is that sometimes, but rarely, (Once I am through with this process, I probably will not ever need to do it again until I get a new liner.) you may want to raise your pH even though you have a SWG. I have no idea why the original poster wants to raise his pH, but depending on where he is in TA, he may want to aerate instead of adding borax or soda ash.
