Thread: will adding muriatic acid protect my FC like CYA
    I have a 20,000gal pool with a SWG that I was planning to clean with muriatic acid(the cell not the pool). My friend was told to just dump the left over acid it into the pool. When I tested after being covered all winter I had 10 ppm FC, PH 7.4, CCs 0, and CYA was 0. The water temperature was 57 Deg so I know the CYA would be a little off but I can't figure out where the Acid went. After opening it up for a few days FC dropped to approx. 2 ppm so I can safely assume that my CYA is truly low. So to my question. If I add the muriatic acid to the pool after removing the scale from the SWG cell will it help protect the FC from the sun or do I need to add the CYA and adjust the ph with Baking soda.
    Thank you in advance.
    16x32 SWG vinyl liner appox. 19k
    38,546
    Re: will adding muriatic acid protect my FC like CYA
    No. Muriatic acid only lowers pH and TA. Cyanuric acid adds CYA.
    Read the "recommended pool chemicals" article in Pool School.
    Ok thanks.
