Results 1 to 12 of 12
Thread: Dirt!!!!!!
    Jun 2013
    Newcastle, Oklahoma
    508
    Dirt!!!!!!
    i cant get it out. i have vacuumed pool 3 times now. come back hours later, and dirt at bottom of pool again.
    i have a triangle shapped very nice vaccuum and hose ($100 for both) that I use hooked to my hayward skimmer. and I shut the second inlet off to double the suction to my vac once its hooked up. last year I only vacuumed pool every saturday unless we had excessive wind or something that dirtied pool.
    thinking that im just stirring it up off the bottom rather than sucking it up, yesterday I vacuumed it, then kept pump running all day while I brushed pool every 15-20 minutes to keep dirt from settling thinking sandfilter would get it out. No dice. unless there is that much dirt in the air (it has been a long time since rain and there is a house on the other side of the pond (80-90 ft away from pool) that they just completed and it has only dirt for a yard.)
    still im thinking it should take a couple of days for dirt to show in my pool from that.... not hours.
    also, my guage on sandfilter is in yellow, last year it stayed in green all year, and I backwashed every 2 weeks. I backwashed for 15 minutes yesterday, plus rinsed it for 3 minutes, guage didnt move. Im thinking winter killed it.....
    do I have to have a guage or will I be okay just backwashing every two weeks and not worrying about tank pressure?
    thanks!
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Re: Dirt!!!!!!
    Very fine particles can make it all the way through a sand filter. You can Add DE to your sand filter to help filter these out. You WILL need a properly operating gauge for this and for normal pump operation.
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    Jun 2013
    Newcastle, Oklahoma
    508
    Re: Dirt!!!!!!
    Quote Originally Posted by JesseWV View Post
    thanks, how much DE do I add? and I am assuming the gauge can be changed out...
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Re: Dirt!!!!!!
    Further more, I wouldn't trust any pressure gauges with preset ranges. You should establish your own "green, yellow and red" operating pressures.
    Everyone's pump set up is different and will have different ranges. Note the pressure after a proper backwash cycle. Backwash again when it increases pressure by 20%.
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    Re: Dirt!!!!!!
    i would stir the water in a circular fashion aka whirlpool
    then leave pool for hours to settle then vacuum dirt to waste
    hopefully it will have settled in a nice pile near centre of pool
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Dirt!!!!!!
    If you prefer not to mess with DE, another option is to add cellulose fiber to your sand filter. This is done using the same procedure described in Add DE to a Sand Filter. Cellulose fiber goes under the most common trade names of FiberClear or ZeoFiber. I have used both brands, when needed, for extra filtering. The main advantage of cellulose fiber is you avoid the hazards associated with inadvertently breathing the DE particles.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Dirt!!!!!!
    Quote Originally Posted by aussieta View Post
    Swirling works like a champ, but you don't have to wait hours. Usually 20 minutes is good, especially with large enough to see.
    If the DE doesn't work, you could try a Slime bag. That's what I finally did on the old pool, and it really helped a lot. These little filters just don't do well. Some of them anyway.
    Essential Links:
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Dirt!!!!!!
    I have a problem as well with airborne dirt. It's just a fact of life living in rural America. The only way I can think of to reduce the dirt would be to enclose the pool.
    Re: Dirt!!!!!!
    I have a similar problem. Its seems like the dirt just returns to the deep end after vacuuming so I assume the sand filter just doesn't filter it out. How much DE should be added to a sand filter? The one time I added DE the pressure would just rise and I'd have to backwash it out but maybe I had added to much. Also, what's a slime bag?
    22650 gallon in-ground vinyl pool
    Hayward sand filter
    Aqua Rite SWG
    installed 6/25/09
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Dirt!!!!!!
    Go look at the windowsills, the patio furniture, the car parked on the drive. If they're covered with dirt, so's your pool.
    The problem is that your water's too clear. You can see a speck of dirt through eight feet of water. People with murky pools don't get upset by some dust. They can't see it. Heck, they probably can't see the drain!
    Your sparklypoolitis is just flaring up again.
    30,419
    Re: Dirt!!!!!!
    Replace that gauge. A correctly working gauge is essential to proper pool water management.....it is not a convenience item.....it is essential.
    Reach down into the pool and "roll" some of that dirt between your thumb and finger. If it is gritty, it is dirt. If it is slimy, it is not dirt.....it's dead algae.
    Update the info in your sig when you get a chance
    May 2014
    Turlock, CA
    55
    Re: Dirt!!!!!!
    I bought a new gauge from TFTestkits, it was inexpensive, good quality, and a piece of cake to install. Plus, I can trust the readings now.
    21K gallon, plaster, 1hp Hayward MaxFlo pump, Hayward 244s sand filter, 3/4 hp Halcyon PB4-60Q booster pump, Polaris 280 cleaner.
