How do you control the speed you want the pump to run when the timer switches to "ON" as per your clock setting ??? The pump starts on at 3,000 rpm and will continue this RPM until the timer switches to off. I would like to lower the RPM's after several hours of pump run time. I mean I can do this manually, but I would like it to switch to a lower RPM automatically.
