Thread: 1.5hp max-Flo VS pump question
    Feb 2014
    Upstate, NY
    390
    How do you control the speed you want the pump to run when the timer switches to "ON" as per your clock setting ??? The pump starts on at 3,000 rpm and will continue this RPM until the timer switches to off. I would like to lower the RPM's after several hours of pump run time. I mean I can do this manually, but I would like it to switch to a lower RPM automatically.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Feb 2014
    Upstate, NY
    390
    Re: 1.5hp max-Flo VS pump question
    OK I just downloaded the manual. The manual is pretty good with instructions on how to program the pump.
    mas985's Avatar
    Pleasanton, CA
    11,741
    You might want to read the manual: http://www.hayward-pool.com/pdf/manuals/MaxFloVS.pdf
    This pump is set to start in prime mode. When Priming has finished the pump will then switch to speed V3.
    The pump will run at this speed for its programmed time then switch to speed V1. The pump will then
    remain at speed V1 until power is cycled or another speed is selected.
    V2 can be selected manually and it will run at that speed for the programmed time and then switch to V1.
    Mark
    Feb 2014
    Upstate, NY
    390
    Thank you Mark.
