Results 1 to 8 of 8
Thread: Limestone Screenings Question
    rkipper's Avatar
    Aug 2013
    East, TN
    28
    I need to fill in a couple of small low spots(2 inch deep) on my leveled surface where we had to pull up a root. I cannot keep re leveling the whole 24 x 15 area just because of small pits caused by roots and rocks or I will be digging to china all day long.
    My first thought was to use the limestone screening material I hear everyone talk about using to level with. I don't want to use it over the whole surface as my area is completely level other than these 2 inch x 2 foot areas, two of them that are mainly in the middle. If I were to fill in those two small areas with screening and compact them, what do you think? Would it wash out? I can get this at our local rock site but since I need a limited amount, can this be bought in bags at like home depot?
    Intex 9' x 18' Ultra Frame, Intex SWG, Intex 2650 Sand Filter Pump, TF-100 test kit
    My pool setup view here
    30,403
    Re: Limestone Screenings Question
    Screenings would probably work well in that situation and should not wash. I have never seen them at Home Depot.
    rkipper's Avatar
    Aug 2013
    East, TN
    28
    Thanks, I will check around tommorow and go by the place here that sells sand and rock.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I used screenings instead of sand for under my liner. The screenings will compact very well. 😎
    Jeff
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    I am using Blue Metal Dust.... Its like crushed rock, but when it gets wet, it sets hard...... Not concrete hard, but very firm.... I'm Australian though and I'm not sure what is the US equivalent..... thank you google, its broken up blue stone........
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Casey's Avatar
    SW PA
    10,423
    The equivalent is screenings laceygirl.
    rkipper's Avatar
    Aug 2013
    East, TN
    28
    I found #10 Sand, which is also known as #10 limestone, at the Rock Yard. I had 3 ton delivered and decided if it was too much I have a lot of other uses for it. I am adding on to the driveway so I used some as base. I hope to complete the leveling today if I don't tire out first.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    That will do the trick...
