Thread: Do I need a vacuum??
    Mar 2014
    Indiana
    28
    I am totally new to pools and I really have no idea if I need a vacuum or some type of cleaner for the pool? I am installing a 27' round. I've read up on on pump and filters, but that's about all I know, lol!!
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Do I need a vacuum??
    A vacuum would be a good accessory.
    You can either get a hose type that works off of your pump, or a dedicated self powered unit. Another option is the automatic pool cleaners. It just depends on how much you want to do with your pool, and how much you are willing to spend.
    30,431
    Yes, you will need a manual vac or an auto-vac. The filter will only remove dirt in suspension.........heavier particles fall to your pool floor and must be vacuumed up.
    Orlando, FL
    690
    What others have said is true. Before I had a setup that would allow for easy connection of an automatic vac, I purchased the Pool Blaster Cyclone @ Walmart for $99. It works great and lasted two years. I did not have any luck or love with the vacs you connect to a garden hose. If you do not want to send the money, you can do a decent job with a leaf rake and a leaf skimmer. This assumes you have a decent pump/filter to pick up the finer particles.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Mar 2014
    Indiana
    28
    Thank so much everyone for helping me become a little more knowledgeable!!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    I highly suggest the Pool Rover Jr. if it's in the budget.
