Thread: Third Year
    May 2012
    Harrah Oklahoma
    5
    Third Year
    This will be my third year year using the TFPC method and love it. I just opened my pool today since it finally hit 60 degrees. Other than some leaves and dirt resting on the bottom from getting around the pool cover, the water was perfectly clear. After filling it back up I did some testing:
    FC: 6.5
    CC: 0
    PH: 7.0
    TA: 90
    CYA: 40
    Added a little borax and it looked good enough to swim...now the wait starts for warmer weather. Foot tapping
    12'X20'X48" AGP
    6300 gallons (according to poolcalc)
    Hayward 180T sand filter
    38,305
    Re: Third Year
    Nice work!
    Casey's Avatar
    SW PA
    10,448
    Re: Third Year
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Third Year
    Good Job!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Third Year
    Goof for you, seems like you got it going your way. That Borax, will bump the pH right up.
    Essential Links:
