Results 1 to 7 of 7
Thread: Sand or Sand/Portland mix under A/G Liner
    Apr 2014
    GA
    9
    I am installing a new A/G. Have had one in the past and helped family members install one also. However, I have never been able to compact sand well enough to maintain smooth bottom for liner installation. Someone told me to mix 7 parts sand to 1 part Portland so that it would compact better. However, will this end up like hard concrete or will it still have some cushion? I'm not a big fan of Gorilla pad or any other cloth type surface. All suggestions welcome.
    Re: Sand or Sand/Portland mix under A/G Liner
    A Sand/cement mix will work ok if it is done correctly. However, I think that a vermiculite mix will give you a better base.
    Support the site
    Apr 2014
    GA
    9
    Thanks so much. Can you tell me a formula? Like Sand/Portland/ Vermiculite? 7/1/? Also, I have seen many posts about using the styrene foam boards. Wouldn't those break down over time? My last pool I just used sand and NEVER was able to achieve a smooth flat bottom.
    There is a commercial product called pool-crete that most people use for the base below a vinyl liner. It is possible to duplicate their formula fairly easily, though I don't know the recipe, but most people simply buy their pre-mix. If you go that route you can get a nice smooth bottom.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    My favourite leveller is blue metal dust..... Its just crushed up Blue Stone.... Its fantastic for drainage and it sets hard....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Apr 2014
    GA
    9
    Where do you find this material?
    Yes I checked into pool-crete but it is very expensive. I don't think I could afford enough of it.
    Any in ground vinyl pool installer should be able to sell you some vermiculite premix.
    Support the site
