Results 1 to 10 of 10
Thread: Taylor Test Kit question
    I have a Taylor 2006 test kit. It gives the option of using a 25 ml sample or a 10 ml sample for the FC test. The question is that the instructions for FC test says to use two dippers of DPD R 0870, not differentiating whether that is for the 10 ml or 25 ml sample. If 2 dippers are OK for 25 ml, wouldn't it be better to use 1 dipper the 10 ml sample? Will the test results be affected either way?
    docelect
    30k gallons in-ground vinyl
    1.5 hp pump 300 lb sand filter
    Polaris cleaner, T15 Hayward SWG
    Jackson, Mississippi
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Taylor Test Kit question
    As long as it turns Barbie Pink, you've probably got enough. If you see one or two granules undissolved, that's perfect.
    38,475
    You can not use too much powder, but you can use too little and skew the test. Like Richard said if it starts with a nice deep pink, you are likely find.
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    1 heaping dipper for 10mL test.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    One heaping dipper in 5 ml is what I've been doing. My new Speed Stir even has a 5 ml line. I don't need .5 accuracy most days (high CYA) and then I don't have to multiply by two, because "Math is hard!"
    20,000 gal in-ground plaster pool with sand filter. Replastered recently. Mostly adding bleach and acid. CYA was high when I took over.
    38,475
    Quote Originally Posted by SwimAustin View Post
    For reference, This can be ok when you are at higher FC levels (like in the middle of a SLAM), but that is not accurate enough to be testing for CCs or for doing OCLT.
    Mar 2014
    Chesapeake, VA
    74
    in getting the test kits, I see the TF-100, is the Taylor K-2005 DPD a good kit or no?
    Dave Graham
    6,000 Gallon 16' x 4' Intex Round Ultra Frame
    Hayward S244-T Sand Filter, Intex SWG, Hayward SF1593 1.5hp Pump, Hayward Thru-Wall Skimmer
    38,475
    NO. The K-2005 is NOT the right kit. You need the FAS-DPD chlorine test ... NOT the DPD chlorine test:
    Recommended Test Kits
    Mar 2014
    Chesapeake, VA
    74
    Ok, I will follow the advice of the Guru's here. TF-100 kit is what I will get
    Dave Graham
    38,475
    For completeness, the Taylor K-2006 has the correct test, but the TF-100 is a better deal.
