Thread: New to the BBB method
    Jun 2008
    Richmond, TX
    14
    I just started on the BBB method. I'm just about out of trichlor tablets and should I continue to use them or just balance it with acid, bleach and baking soda? The place I get my water tested is pushing the Bioguard Silk tabs and Poollife multi-purpose tabs
    20,000 gallon gunite with colored plaster,
    Hayward 60 DE filter, 2.5HP Hayward pump, Hayward Phantom cleaner, Rainbow 320 Chlorinator, Nature 2
    Jun 2008
    Marana, AZ
    347
    Re: New to the BBB method
    If you're just about out - don't buy any more. Just use the bleach and stuff. If you're wondering if you can use what you have left, that depends on your CYA levels. The gurus here are going to tell you to invest in a good test kit. Anyway, since the trichlor adds CYA, if your CYA is high already (which it will be if you've been using trichlor for any length of time at all) don't use any more. You will just need to drain some of your water. If it's low, and you decide to use up your pucks, keep an eye on the CYA (stabilizer) levels.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    ktdave's Avatar
    Katy, TX
    888
    1.read the Pool School
    2. get a good test kit: TF-100, or Taylor k-2006
    Come back here and ask more questions
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by ktdave
    Ditto. What he said.
