Results 1 to 10 of 10
Thread: How much chlorine does it take to ruin a PVC elbow connection?
    Feb 2013
    Pool Country
    138
    Someone added trichlor tabs to the trough of the negative edge. The negative edge goes to a surge tank. The negative edge system runs 24 hours a day.
    The pool builder is claiming that the trichlor tabs ruined one of his PVC elbow joints.
    Thanks
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,109
    Re: How much chlorine does it take to ruin a PVC elbow connection?
    My gut says it wasn't the chlorine that caused the issue, rather the drop in pH the trichlor caused.
    Feb 2013
    Pool Country
    138
    Muriatic Acid is Hydrochloric Acid, 35%.
    Is appears that PVC has "Good" chemical resistance to even straight muriatic acid.
    Saltwater Chlorine Generators pump chlorine through plumbing, although trichlor tabs are acidic.
    Feb 2013
    Pool Country
    138
    It appears that PVC has "Excellent" chemical resistance to chlorine.
    Jul 2011
    Eastern Ohio
    7,109
    Do you have a link to this case, so we can read all the facts before further guessing any causes??
    Feb 2013
    Pool Country
    138
    I'm not allowed to post links.
    38,521
    I think it is ok if an admin requests one
    Plus you are not trying to sell something.
    No amount of trichlor is going to damage PVC chemically. PVC is impressively chemical resistant. Trichlor tablet feeders are made out of PVC, and when they have problems it is not because the PVC components are damaged.
    My guess is that if the joint failed, then the joint was probably not glued correctly.
    I would ask to see the failed joint. The cause of the failure will probably be obvious if you are familiar with glue joints.
    If you can post a picture of the failed joint, we might be able to determine what the cause of the failure was.
    Support the site
    Feb 2013
    Pool Country
    138
    Quote Originally Posted by Leebo View Post
    No, it's a local undocumented event.
    I think the following is the proverbial nail in the coffin.
    Quote Originally Posted by JasonLion View Post
    Thanks
