Results 1 to 14 of 14
Thread: Where to buy CYA
    Where to buy CYA
    Hi,
    The CYA level in my pool is very low and I need to raise it to 40ppm. I did the pool calculator and it says 3.2 lb. The lowest I could find was Chem Tek 4lb in Lowes for $16. The liquid one seems very costly. If anyone has a preferred place to buy cyanuric acid/stabilizer, could you please suggest? Thanks
    Regards,
    Ani, Phoenix AZ
    12888 gallons free form (3'-5'-4') Pebble Sheen Inground
    Jandy ePump, 460 Sq ft Catridge filter
    In Floor cleaning system - Clear O3
    38,290
    Re: Where to buy CYA
    Where ever is the cheapest ... Walmart usually has the smaller quantities at good prices.
    Liquid is not worth the extra cost.
    Amazon usually has good prices, as does eBay.
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    That's about as low as you will find it. If you look really hard you might be able to save a buck or two at most. Get it at Lowe's.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    Thank you.... I will try amazon and eBay too
    Regards,
    Ani, Phoenix AZ
    Smykowski's Avatar
    Sep 2011
    3,065
    Search using Google shopping. I had good luck last year.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    I have found it at Lowe's and Wally World.
    Jan 2013
    Houston, TX
    1,079
    Lowes for me last time...
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Walmart had a 4.5lb bottle for 20$. Worked great for us
    Brian, Pool newbie in Atlanta, GA. 24k IG vinyl pool, Circupool SI-45 SWG (purchased 3/2014) , Hayward Pro Series Sand filter S220T, Pentair 1hp 2-speed superflow (thanks Jbizzle!), TF-100 test kit w/ SpeedStir
    Removed -> Hayward 1HP Super pump SP-1607-Z1-M
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Home Depot is the same price by me.
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    ebay... I just bought some at Lowes, 4 lbs for $17.something. Then found 10 lbs on ebay for $30 with free shipping. Now I just fournd it for even cheaper on ebay... Going to take what I got at Lowes back next time I am over there.
    $27.98
    10 lbs 100 Cyanuric Acid Swimming Pool Stabilizer Resealable 2 5 Packages | eBay
    Owner since August 2014. 21,500G Liner In ground Pool with attached 600G plaster in ground hottub. TF-100 Test Kit, Filter: Pentair TA60D Clearpro Sand (HTH) Filter. Pool: 1 Drain, 2 Skimmers 4 Returns. Hot Tub: 1 drain, 1 skimmer, 2 returns. Hot Tub/Pool run by Sta-Rite Dura Glas Single Speed 1.5hp P2RA5F-182L pump with Emerson K63CXESE4972 motor. Spa jets run by Sta-Rite Dura Glas H/L model number unknown.
    Nov 2015
    Ok ok
    822
    Thx for the tip, just ordered it .
    ~14K gallon - AquaRite AQR15 SWG - pool Newly plastered on April 9 2016
    TF100 kit - STA-RITE SYSTEM3 Modular Media Filtration - Model S8M150
    Pool water supply from on site water well = CH of ~350 and TA of ~350
    Doheny's Discovery Automatic Robotic Cleaner/Pentair Model 011018 VS Pump
    Sundance Altamar Hot tub separate from pool / central Oklahoma
    Jan 2015
    Tampa Bay, FL
    16
    I got 20 lbs for $40 on ebay from backyardpoolsuperstore a couple of weeks ago. Free shipping. Best price I could find. They have a web site too that charges the same price, but adds shipping cost.
    17,700 gal fiberglass outdoor, rectangular, chlorine-sanitized in-ground pool, 35x15 ft2. Pentair FNS Plus D.E. Filter (48 ft2). Pentair Whisper Flo 4 (1 hp) pump. Two skimmers (@2- and @4-), two returns (@7- and @10-), one vacuum (@4-o'clock position skimmer), no main drain. Autofill device adding ~1000? gal of utility water per week. TF-100 test with speed stir.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I go wherever I can find HTH brand. They're all 100% CYA or close, but HTH has very fine granules, almost like beach sand. Dissolves much faster than the larger granule CYA I have purchased before that.
    Isolated Spa - 345 Gallons
