Page 1 of 6 1234 ... LastLast
Results 1 to 20 of 109
Thread: Ready.....Set.......Build!
    Mar 2014
    Imperial, CA
    70
    I'll use this to document my pool and patio build in Imperial, CA.
    it's a 32' x 16' rectangular pool with an 8' long 2' jut out for a bench, and another 4' x 4' jut out for a stepped entrance. It will be 3 1/2'-6'-4' depth.
    Here's the equipment, coping and plaster:
    Hayward Aqua Rite 40k swg
    Stonescapes mini pebble plaster finish. (Color tbd, think this decision is almost made)
    Pentair intellibrite colored light 12v
    Travertine coping
    Pentair intelliflo variable speed pump
    Pentair 60sf fans plus DE filter
    All comments welcomed, anything stand out wit the equipment or anything. Wish my yard was bigger, not leaving ourselves much grassy area.
    Oh yeah the pictures. Here's a couple computer renditions. The coping isn't accurate, but you get the idea.
    I wish my background was that too, I'm in the middle of a neighborhood. Permits should be applied for in the next couple of days. That black rectangle area is just a flower bed.
    Mar 2014
    Imperial, CA
    70
    Re: Ready.....set.......
    Also forgot to mention that the decking near the fence is raised 18 inches because I currently have a small retaining wall there. My back fence is a culdesac, no house behind me, and it's slightly higher than my yard. My current retaining wall will be continued from where the decking ends.
    Sep 2013
    Nashville, TN
    382
    Looks good, is this another DIY build?
    18x36 Vinyl, sports depth, 8' Roman steps at each end. Hayward 1.5hp 2speed pump, catridge filter, 2 skimmers, no main drain, 3 SR Smith Treo LED lights
    Mar 2014
    Imperial, CA
    70
    No DIY, using a local PB.
    Mar 2014
    Imperial, CA
    70
    Re: Ready.....Set.......Build!
    First hiccup, originally we had a verbal with the city that we could obtain a waiver to build within 3ft of the back fence. City code calls for 5ft, we believed the property behind us was owned by the city. The inspector looked further into it and it is private property. Now finding out if we can get an agreement with the property owner to get a waiver, or the city may make us push it back 2 feet, agreement or not. Hopefully we can get an answer tomorrow.
    My yard is not very big, so if we have to move it I may have to do some modifications to the design. I believe it has to be 3' from the patio also, I can't remember the measurements and how that will affect everything.
    Booooo. Hopefully you won't have to change it. It's going to be lovely!
    Vette, DH, & 2 DDs Our IG AGP Build
    In-ground Radiant 24', 1.5 Pentair IntelliFlo pump, Hayward Sand Filter
    CCisotope's Avatar
    Aug 2013
    Cypress, TX
    136
    Nice design, simple and elegant. I think your yard space is like mine. Have you decided what you are going to put on the back retaining wall?
    IG Gunite 30k gallons, custom WetEdge finish with glass beads, spa, Pentair 520sq. ft. Cartridge Filter, Pentair 3HP intelliflow V.S pump, Pentair 400K BTU Heater Master Temp, Pentair 2HP Whisperflo- Model WF-28, Silencer Air Blower 1.5 HP, Pentair Boost Rite Universal Booster Pump, Rainbow 320, Easy Touch 8, My pool build:http://www.troublefreepool.com/threa...ypress-TX-Pics
    Mar 2014
    Imperial, CA
    70
    I'm going to run the waterline tile up to the top of the wall. Haven't picked the tile out yet.
    The guy in the city we have to talk to is out today. I'm a little worried about having to deal with extra city red tape and delaying the start of the build.
    If we pushed it back 2 feet, the entrance steps would be 4 feet from the end of my patio. Does that seem too close? Code says it's ok, I'm just wondering functionally. Also my planter box loses 2 feet in length, not that big of deal.
    Benefit of pushing it back, the rear deck that's raised goes from 3 to 5 feet. A much more reasonable size to put a lounge chair or something on.
    Mar 2014
    Imperial, CA
    70
    Ok, decided to just push it back 2 feet. Here's a quick depiction of that, doesn't look much different. Hopefully plans can be submitted Monday or Tuesday so we can get our permits.
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    Looks like it will be a beautiful pool. It would be cool if you had a waterfall or some sort of fountain or two coming out of that wall.
    Why did you pick 6'-4" for the depth of the middle part? It is too shallow to dive, and I'm just wondering if you might be more happy with something along the lines of 5 to 5 and a half feet.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    Mar 2014
    Imperial, CA
    70
    I figured it gave a deep enough place to throw things that the kids can swim to the bottom and get. Plus both me and the wife are 5' 11", so I wanted a place we couldn't stand. Our kids are on the taller side too. It's 3 1/2' on one end 6' in the middle and back up to 4' on the other end.
    Thought about the waterfall, but with the patio and pool, we are close to our budget level so didn't want to add many other expenses.
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    I misread the depth. I thought you were making the middle 6 foot 4 inches, and that seemed a bit odd to me. I have read that some others like the sport depth, which is 5'-6" in the middle, if I remember correctly.
    CCisotope's Avatar
    Aug 2013
    Cypress, TX
    136
    Quote:"Thought about the waterfall, but with the patio and pool, we are close to our budget level so didn't want to add many other expenses."
    Choices, choices...it's going to look great even without the waterfalls. Our waterfall has a little leak at the moment so think of it as one less headache to deal with if you don't get one.
    Mar 2014
    Imperial, CA
    70
    Somehow I posted something twice? I'll just edit this and use it as a response.
    That's a good way to look at it CCisotope. Other than that, I kind of wanted to keep it as clean and as simple as I could. Didn't want it to get to busy with water features, the yard is small enough. Ok, ok that's how I tricked myself into not spending extra money.
    Mar 2014
    Imperial, CA
    70
    Contract is officially signed, deposit paid, and permits should be submitted on Monday! Getting a little excited. Have to make sure I take some before pics this weekend.
    Mar 2014
    Imperial, CA
    70
    Permits were submitted today. Let's see how long this takes, as soon as the plans are approved the PB said he can start excavating the next day. Have to remember to take before pictures, nothing to it really just a rectangle yard. I'll try and get them up tomorrow.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    Quote Originally Posted by JNS101879 View Post
    Maybe so, but it looks like you have a nice mountain view!
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Mar 2014
    Imperial, CA
    70
    I'll see if I can get the PB to throw in those mountains for free.
    Good news is that the permit was approved today! Only one day, wow!
    The plan is the PB will start prepping for the dig tomorrow and start digging tomorrow.
    And the before pictures.
    Those A/C units will be relocated.
    Vegas Kid's Avatar
    Dec 2013
    Cypress TX
    187
    Looks good.
    Try and plant something tall in the corner to get privacy from that 2 story house across the way.
  20. Back To Top    #20
    Mar 2014
    Imperial, CA
    70
    Yeah not sure what I'm going to do there, I have the same thing in the other back corner of the yard. No one behind me at least . That corner is going to be cement, I may attach a sail to the fence and patio. I'm in the desert so you can always use the shade.
