Thread: Part Recommendation for Leaking Hayward S244T
    Jun 2012
    Ontario Canada
    12
    Hello,
    My Hawyard S244T Filter has a very fine/slow leak from the collar during normal operations, typically at start up. A slight leak also appears from the pressure guage and multiport handle while on rinse setting.
    What parts should I be replacing? Spider Gasket? Addtional parts/O-rings?
    Thanks as always
    Andrew
    30K Gallon 18x36, Sand Filter, IG Vinyl, 1HP Hayward, Aquarite SWG, Jandy Lite2 Gas Heater
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Part Recommendation for Leaking Hayward S244T
    Spider gasket is not designed to be replaceable on that multiport.
    The leak at the pressure gauge can probably be fixed by removing and replacing the teflon tape.
    The collar leak is going to be the o-ring. I had the exact same thing happen on mine (180T) last year, and I just took the multiport off and reseated it and it went away. If that doesn't work, probably needs another one.
    As for the handle leak, can you be a little more specific? I can't picture it.
