Thread: Black algae on fountain
    I started servicing a new salt system pool. It has two fountains; one of them looks perfect, but the other one has black algae. I tried to brush that with little luck. Can anybody please recommend any chemicals and/or anything else on how I can remove this algae?
    Thanks and appreciate your kind feedback.
    NUbee!
    Rancho Santa Margarita, CA
    Gallons? Unknown. Medium sized pool.
    Filter? I think cartidge. Big beer can looking device with pressure valve on top running around 30 PSI
    Inground plaster pool.
    Spa above spills into pool. Waterslide above Spa spills into pool.
    Heater: Purex Triton MiniMax
    Vacuum: Hayward Navigator
    Pool guy does regular water maintenance.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Black algae on fountain
    Removing black algae will take equal doses of patience and persistence. If it's just the fountain, you can apply some chlorine and then brush the area. The brushing is just as important as chlorine (FC) in removing black algae. The brushing is necessary to remove the protective film that black algae forms in order to protect itself. Removing this film will allow the FC to work at killing the algae. However, I would test the pool water and post those results. It very well could be that algae is hiding somewhere else in the pool. Be sure to check behind pool lights and around ladders as these are some of algae's favorite hiding spots. Do not bother with algaecides of any kind. They are useless once you have an algae outbreak.
    Once you post some test results, we'll take it from there. Also, a pic would be helpful.
