Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Help with algae
    Jun 2008
    Houston, TX
    68
    Help with algae
    I recently purchased a home with a pool and I must admit I am a little overwhelmed right now. I knew nothing about pools coming into this and it is slowly turning into a money pit. I have already had to replace filter elements, a pump seal, then all of the chemicals.
    The water was very cloudywhen I bought it...turned out it was bad filter elelments letting DE pass. I finally got that problem resolved, but now I have a problem with algea growing on the walls. I shock and brush and within a few days it's back! I have never been able to get the water to really sparkle.
    I took a sample to the pool store this morning and here are the readinsgs.
    Temp - 90
    Saturation idx - 0.4
    TDS - 750
    CYA - 63
    TC - 0.5
    FC - 0
    pH - 7.7
    TA - 106
    Adjusted TA - 87
    Total Hardness - 314
    I was told to add 4 scoops of bicarb and wait 2 hours. Add 1 1/2 scoops aof acid, then wait another hour and add 3 lbs of shock. She said I needed to get TC and FC balanced out and then add an algeacide. She said that algeacide was the only thing that would get rid of mustard algea. After reading this forum, I am to believe that chlorine is all that is needed to get rid of it. Any help is appreciated.
    Pool Specs:
    16,000 gal. IG - Plaster - Auto Chlorinator
    FNS 48 DE Filter - 2HP Centurion Pump (A.O. Smith)
    Hayward HeatPro Heat Pump - Polaris 360
    May 2008
    North Carolina
    79
    Re: Help with algea
    You need to get your pool to shock value and keep it there. Use the pool calculator in the links on the home page to find out what your shock level should be. You must keep your pool at this level until it holds overnight (dropping less than 1 ppm).
    All the while brush and vaccuum as much as you can. It took me over three weeks to turn my pool from swamp sludgy water to crystal blue. It was a lot of bleach - more than I ever imagined.
    Keep at it and be diligent and it will turn.
    16 X 34 21,000 IG Vinyl Liner
    1 1/2 Hayward SuperPump
    New Sand Filter (had cartridge - hated them)
    Jun 2008
    Marana, AZ
    347
    Re: Help with algea
    With CYA that high, you better make sure that shock doesn't have any stabilizers added! Granulated shock often does. Either bleach, (unscented and without any laundry additives) or liquid chlorine is better. (The only difference between plain bleach and the liquid chlorine they sell at the pool store is the strength.) The pool calculator you can get to from this forum (someone will be along soon who has the link) will tell you how much you need.
    And yes, you can get rid of algae using chlorine alone. If you do decide to use an algecide, though, stay away from copper. Polyquat is the best.
    I'm not sure if you want to get your PH down before shocking or not. I'm new myself, so I'm just getting the hang of this too.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Jun 2008
    Houston, TX
    68
    Re: Help with algea
    Quote Originally Posted by branchop
    Forgive my ignorance, but how do I amintain shock level? Do I simply add more shock every day?
    Pool Specs:
    May 2008
    North Carolina
    79
    Re: Help with algea
    I'm sorry- shock is simply (in BBB terms) - bleach. Just a higher concentration than normal. My pool per the pool calculator should normally be about 4-7 ppm. However at the bottom of the calculator it will show you what the shock levels should be. (mine is around 16)
    At the top of the calculator put what you want your FC to be (for shock I would put 16 - for normal I would put 6) and it will tell you how much bleach to add!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Help with algea
    Hi h2o,
    You can read about getting rid of the algae here: category/pool-school/defeating_algae
    Some time reading in Pool School will help. Link is at the top of each page in the sub-heading.
    A link to Jason's Pool Calculator is on the home page, left side, links section. Also a link in my sig. You can save a copy to your computer.
    Welcome to the forum
    You're done SLAMing when:
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Help with algea
    Quote Originally Posted by h2o
    Temp - 90
    TDS - 750
    CYA - 63
    TC - 0.5
    FC - 0
    pH - 7.7
    TA - 106
    Adjusted TA - 87
    She told you to add 'bicarb' and then 'acid'? What kind of "acid"?
    Good ole' chlorine is all you need and you are in the right place to get help. Welcome to TFP!
    Jun 2008
    Houston, TX
    68
    Re: Help with algea
    Quote Originally Posted by frustratedpoolmom
    Yes ma'am. 4 scoops of sodium bicarbonate (12 lbs I think) then, 2 hrs later, 1 1/2 scoops of muratic acid.
    I've been doing a lot of reading here today and it seems I've been "pool stored" already. I just spent $150 on pool chems last week. I do have another question...I shocked to pool with 3 lbs of cal-hypo at 6pm. Since I do not have a test kit (yes, I know I need one) how should I go about maintaining shock level? Should I just add a couple of more lbs. of cal-hypo in the morning? I will get the water tested again at lunch tomorrow.
    Pool Specs:
    loridud's Avatar
    Jun 2008
    Texas
    19
    Re: Help with algea
    Please read my entire post(s) under: "Just getting started.....New-home-1st-time-pool-owner-a-green-pool-help!!" (it is recent)
    I just bought a home, had a pump break, had a beautiful pool turn into a swamp, have been fighting the algae war (4th day), and I am a 1st time pool owner as well. I joined this website and have learned SO MUCH in just a few days!! And my pool is now sparkling and beautiful again.
    I think you could benefit from reading through my "algae war story!!"
    Lori & Aaron D, Trophy Club, TX
    ~~30Kgal--IG gunite--attached spa--Pentair Cartridge filter--1.5hp Challenger pump~~
    11,969
    Re: Help with algea
    I see you have a plaster pool. See, I'm not real knowledgable about CH and plaster surfaces, and using CAl-hypo increases your calcium.... you are at 314 now and I believe the range is 200-400...
    Without a test kit, shocking and holding it there is a problem, as you are just guessing, or making frequent trips to the pool stealer risking your pocketbook with every trip....you have to PROMISE US YOU WON'T BUY ANYTHING....LOL
    Order a good kit, tonight. You won't regret it. I got the TF-100 from Duraleigh, the links on the homepage. A good test kit gives you complete control of your pool water.
    Jun 2008
    Houston, TX
    68
    Re: Help with algea
    Quote Originally Posted by loridud
    I have read that thread already.
    Pool Specs:
    Jun 2008
    Houston, TX
    68
    Re: Help with algea
    I promise...I won't buy anything. Well, I do need more DE.
    Pool Specs:
    Jun 2008
    Houston, TX
    68
    Re: Help with algea
    Newest numbers...
    PH - 8.2
    TA - 134
    FC - 10
    TC - 10
    CH - 335 (total hardness)
    CYA - 72
    The pool store told me to add 48 oz. of muratic acid to bring the pH down. I plugged the numbers into the pool calc and added 2 more lbs of cal-hypo to bring it back to 20ppm.
    I shocked yesterday evening, last night, and around 8am this morning. I took tje sample to the pool store at noon. This is difficult seeing as how I don't have a test kit (ordered a TF-100 this morning) and I have no way of knowing what my FC level is unless I make a trip up to the pool store. That and being at work all day only allows me to shock in the morning, at lunch and in the evening. My saturation index is also high. It is at 1.
    Any suggestions?
    Pool Specs:
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Help with algea
    Leave your pH alone since test results can be wrong when chlorine levels are high. I hate to suggest more money, especially since you'll have your TF-100 later this week most likely, but Walmart sells a kit for about $15. You can use the dilution method to extend the range of the kit (at the expense of some accuracy) and keep an eye on your chlorine until you have the TF-100. Add 3 parts distilled water to 1 part pool water, and test the mixture. Multiply your reading by 4 to get a good indication of the actual chlorine level.
    Jun 2008
    Houston, TX
    68
    Re: Help with algae
    Thanks for all of the responses. I'm a little torn right now. Do I just eat the $150+ I just spent last week on cal-hypo and tabs or should I use it up before switching over to the BBB method? Obviously, once I get this algea situation under control I will need to do a partial drain and refill to bring the CYA down. Your thoughts?
    Also, is it bad to have a saturation level of 1?
    Pool Specs:
    Re: Help with algae
    Your CH and CYA levels are both already fairly high. If you keep using trichlor and/or cal-hypo for any length of time, one of them will get too high and probably start causing problems.
    Jun 2008
    Houston, TX
    68
    Re: Help with algae
    But if I do a partial drain and refill, shouldn't both of those numbers come down?
    Pool Specs:
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Help with algae
    Short answer, "Yes".
    Jun 2008
    Houston, TX
    68
    Re: Help with algae
    Okay, thanks for all the help. I think I am going to go that route for the short term. I just hate to **** away that much cash. I have read enough to convince me to try the BBB method though.
    Pool Specs:
  20. Back To Top    #20
    30,419
    Re: Help with algae
    h20,
    You won't throw it away. Save the Cal Hypo for shocking and the pucks for when you go on vacation.
    In small doses, both these products fit in with BBB very nicely.....you'll see.
