Page 1 of 5 1234 ... LastLast
Results 1 to 20 of 97
Thread: Building 27' AG Pool
    Mar 2014
    Thomson GA
    166
    I am constructing my first permanent ABG and have taken the advice given on this forum to heart. I have searched this forum and much of the information either says or implies that there is a crusing weight of water on the pool bottom. Some posts say that the weight of the water will crush a styrofoam bottom or other the pool bottom. It has caused a lot of doubt on my part that I can safely build this pool and why in the world they are allowed to manufacture and sell these pools in such an indiscriminate manner. I decided to apply some basic math to the problem and determined the following:
    27' round pool manual says it holds 17,000 Gallons.
    17,000 gallons
    x 8.5 #/gallon
    = 144,500 pounds of water in pool.
    27' pool = 13.5' radius
    13.5' x 13.5' = 182.25 sq feet
    182.25 sq ft x pi = 572 sq ft of area for 27' round pool
    convert area to sq inches so psi can be determined
    12" x 12" = 144 sq in per sq foot.
    572 sq ft x 144 sq in = 82368 sq in of area in a 27' round pool
    calculate psi on the botom of the pool
    144,500 pounds of water / 82368 sq in = 1.75 psi pressing on the bottom of the pool.
    I feel after this calculation that I can build this pool without having to over build the pool. I am making this post to help allay fears of other people about the effect of the water pressure on the pool bottom. The foam products that are avail in my area have a rating of 10 - 15 psi crush strength so are suitable for my pool. I talked with another local ABG owner that has had his pool for 5 yrs with a white foam bottom that he say had no divots or other depressions in the floor. These calculations seem to confirm this and the white Styrofoam is less expensive.
    I have installed the pads for the uprights and am now leveling the pool floor.
    Gerry
    27' x 54" AG Salt Water Pool Installed 2014, Hayward 23" Sand Filter, 1 HP 2-Speed Power-Flo Matrix Pump, AQ-TROL SWG, TF-100 Test Kit
    Mar 2014
    Thomson GA
    166
    Re: 1.75 psi pressing on the bottom of the pool
    Thought I would add a couple of pictures these show the stepping stones that are ready for the uprights.
    Gerry
    Mar 2014
    Thomson GA
    166
    Couple more Pictures
    Gerry
    mas985's Avatar
    Pleasanton, CA
    11,741
    You went through a lot of calculations to determine pressure but in reality, you only need to know the depth of the water to calculate the pressure.
    PSI = Depth (ft) / 2.31 = 4 / 2.31 = 1.73 PSI
    Mark
    Mar 2014
    Thomson GA
    166
    Thanks Mark that sure beats my convoluted calculations. What is the 2.31?
    Gerry
    38,305
    That's the magic number
    mas985's Avatar
    Pleasanton, CA
    11,741
    Yes it is a magic number. It converts feet of head to PSI. For static head, the depth of the water equals the static head so to derive this constant you start with the weight of water which is 62.3832 lbs/cu-ft and then just change the units:
    Head ft/PSI = (144 sq-in/sq-ft) / (62.3832 lbs/cu-ft) = 2.31 ft / (lbs/sq-in) = 2.31 ft/PSI
    Mark
    Mar 2014
    Thomson GA
    166
    Thanks Mark. The ft/2.31 makes it much easier to find the PSI.
    The pool has the bolts holding the walls together spaced very close together at the bottom and to some extent at the top. The center of the wall has a greater spacing between bolts. Each side of the SS panel has 31 bolts and nuts with 13 nuts and bolts in the bottom part of the wall. Is the force of the water pushing out that great?
    I have the walls up and will be installing the foam floor and cove today. I was too tired to take pics yesterday but will post some pics this morning.
    Gerry
    mas985's Avatar
    Pleasanton, CA
    11,741
    The force of the water is greatest at the bottom and zero above the water line so that is probably why they have more bolts closer to the bottom. While 1.73 PSI does not seem like a lot of pressure, the total weight of the water is 143,000 lbs so the structure still needs to be fairly strong to hold it back.
    Mark
    Mar 2014
    Thomson GA
    166
    Mark I had forgotten about the total weight of water when I asked that question.
    Gerry
    Mar 2014
    Thomson GA
    166
    A few more pictures as the build progresses. I used 19 pieces of 4'x8'x3/4" extruded foam and 5 rolls of duct tape for the foam floor.
    Foam floor complete
    Liner removed from box
    Laying out liner
    All hands on deck to stretch out the liner
    Gerry
    38,305
    Duct tape is not a good waterproof tape. It would have been better (and less noticeable because it is much thinner) to use homewrap/weatherbarrier tape (like for Tyvek).
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Nice job on the foam floor !!
    Jeff
    Mar 2014
    Thomson GA
    166
    Cove being installed and taped -- the cove with the gap had not been installed it was just laid out. All the cove was butted tightly together and each joint taped. The bottom joint between the foam cove and the foam bottom was also taped. The cove tape was a single layer. No tape was applied between the top of the cove and the wall.
    J-hook hung over the wall
    We adjusted the liner by pulling from different directions to remove most of the wrinkles so the sides hung straight and got all the wrinkles out of the floor. The bottom liner seam fell on the cove all the way around.
    Gerry
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Your cove wasn't the peel n stick kind ?
    Jeff
    Mar 2014
    Thomson GA
    166
    Now comes the Tom Sawyer part. Put about 2" of water in the bottom and told the kids they can play in it. They did not know they were removing the wrinkles. They slid on the bottom in all directions for hours. The foam bottom was smooth and had enough give to allow all the wrinkles to disappear.
    There is about a foot of water in it now and the walls are hanging straight.
    More pictures tomorrow.
    Gerry
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Looks great !
    Jeff
    Casey's Avatar
    SW PA
    10,448
    You are going to love that liner! I have the same one!
    Mar 2014
    Thomson GA
    166
    Thanks Jeff
    Thank you Casey - my DW was hoping that it would not be so blue. Yours look wonderful. I hope we can keep our pool water looking like yours.
    Gerry
  20. Back To Top    #20
    Casey's Avatar
    SW PA
    10,448
    Follow Pool School to the T and your water will look just like mine!
    I can't remember when this one was taken but it doesn't look dark at all in this pic...
    My current avatar and steps into the pool.
    How it looked upon opening yesterday.
    It looks like your pool will get some shade. My pool is in full sun ALL day long.
