Thread: pool pump priming every startup
    Been working on a multitude of issues.... all but one has been solved.
    Have a pool with flow-over spa attached. Every time the pool starts up in the a.m. the pump has to self-prime. Although the pump is designed to do so, it still is extra wear and tear on the equipment.
    I can finally say there are no WATER leaks in the system. Does anyone have any suggestions to isolate where the air can be leaking into the system when there is no drippage? I have a pump / filter / heatpump / salt system.... in that order. Again, no moisture around any of these items - with the exception of the heatpump only when it is running. Thanks in advance.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: pool pump priming every startup
    More than likely it's a leak before the pump. Check out the article on Suction Side Leaks http://www.troublefreepool.com/conte...side-air-leaks
    You probably have a smaller leak. Suction leaks sometimes seal under the vacuum from the pump.
    How high is your pump above the pool water surface?
