Results 1 to 8 of 8
Thread: Radiant metric 27' round semi in ground pool
    Mar 2014
    NW suburbs IL
    31
    I am having a 27' round pool semi in ground 2'. I first looked at the oasis by wilbar, an all aluminum pool. Then saw the radiant also all aluminum w insulated walls. Can anyone who,has either of these pools semi in ground give me some advice on if the radiant is the way to go as far as durability and longevity?
    I also need advice on pump size, filter size (cartridge), and heater size. What about solar cover reels for round pools. Are there any other then those that mount in the center of pool and need to be removed?
    Any and all experienced AGP owners w knowledge of these things would be greatly appreciated.
    Re: Radiant metric 27' round semi in ground pool
    We have the 24' installed IG. We've had it one year now. We had a PB professionally install it and it was worth the cost.
    From what I hear Radiant is about the best. In fact, I think our pool has a warranty for life. Because we put it in the ground, we had to buy IG equipment. We have a 1.5 hp pentair variable speed pump and a large Hayward filter (idk the size off hand). We won't be getting a cover or a heater so can't help you there.
    I plan to do a build thread once we get started on the deck next week. Right now ours is just a pool in the ground surrounded by grass. But if you search my posts you'll see a few pics.
    Good luck!
    Vette, DH, & 2 DDs Our IG AGP Build
    In-ground Radiant 24', 1.5 Pentair IntelliFlo pump, Hayward Sand Filter
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    You can even transfer the lifetime warranty of a radiant pool if you ever sell your house... I'd love one, but I can't get them in Australia....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Mar 2014
    Indiana
    28
    I just purchased the Radiant, we are installing AG for now but may bury it in the future. Would love to hear from anyone who owns this pool. I really like the ease of installation and that the insulated walls keep the pool water 5-10 degrees warmer than a traditional AGP.
    Mar 2014
    NW suburbs IL
    31
    Well I've decided to save the 3,000 and go w the oasis. I wasn't buying the radiant so much for the insulation as most of the heat loss is from top of water. I did feel it was a sturdier looking pool but couldnt get any confirmation on that. My installer feels more confident putting oasis in ground . I've already put money down and plan to make final decision tomorrow .
    Jan 2014
    North/West Ohio
    13
    Moonlite swim:
    What model of the oasis pool do you purchase? We are looking at a Doughboy pool that we can semi install about 24" deep. But am open to options. We also looked at the Radiant but our dealer and installer, priced us out of the market. Any words of wisdom on burying a pool would be greatly appreciated. I see you live in IL. I live in northwest Ohio so I think our winters & summers are about the same. Keep posting updates on the build.
    Mar 2014
    NW suburbs IL
    31
    The oasis pool is an all aluminum pool that can safely be put 2' in ground. The great escape is whom we purchased through. 27' round pool, w upgrade on stairs, 200,000 btu heater, 2hp 2 stage pump, large cartridge filter, mineral system to reduce chlorine usage, pool cove around bottom of pool, 28' solar cover, hoses, light w fountain by aqua ???, and 3 yr. warranty on all, = $10,600.00. Excavating will cost us another $3,500 to $4,000 to have it put 2' in ground. We decided the radiant was not worth the cost since the primary heat loss is from the top of the pool water and the insulated walls wouldn't prevent heat loss from top of pool.
    Feb 2017
    il
    2
    Quote Originally Posted by Moonlite swim View Post
    Would love to know who installed your pool
