Thread: New plaster pool, first tests
    Vegas Kid's Avatar
    Dec 2013
    Cypress TX
    187
    New plaster pool, bout a week old.
    Builder did Acid startup, brushing pool 2x daily. Have an inline chlorinator currently running with 4 chlorine tabs. Will switch over to SWG in a month.
    I'm assuming my water levels will want to be inline with a "chlorine" pool until I switch over to SWG and adjust accordingly.
    Got the ol TF100 kit and did my initial test.
    FC: Didn't turn pink so I'm guessing not much chlorine is in there. For sanity check the daily chlorine check showed nothing either. I adjusted the in-line chlorinator to a higher level since my CYA is non-existent as well.
    PH: Nothing much there either. Below the 6.8 level on the sight glass
    TA: Showed nothing
    CYA: Showed nothing. Didn't get cloudy at all. Figure this is common with new pools.
    CH: 325...actually got a measurement!
    I'm guessing since it's a new pool the numbers will be skewed for the first week or so.
    Wondering if I need to add some more chlorine immediately besides the tabs in the chlorinator or just wait a few more days and check again.
    Re: New plaster pool, first tests
    Is the builder going to neutralize the acid?
    Support the site
    Vegas Kid's Avatar
    Dec 2013
    Cypress TX
    187
    Quote Originally Posted by JamesW View Post
    Not sure, I'll add some Borax from the house. I have a few other buckets of stuff he left me.
