Thread: Pre Pool opening chlorine addition to limit algae growth??
    I have a mesh green pool cover for my in-ground (details in signature). I would like to keep it as clear as possible before I open in another month or so and from experience last year it started out pretty green. Should I dump some liquid chlorine in while the cover is still on or maybe put a flouter in the deep end?
    Any advice on this subjects?
    Cincinnati OH, 20K Vinyl IG rect. 16x36, Hayward Super II pump with Hayward 60 GPM sand filter, Hayward H150 heater, space age blue solar cover, one skimmer and one deep end drain, two returns, makeshift fountain on one return for aeration. TF100 test kit.
    38,262
    Re: Pre Pool opening chlorine addition to limit algae growth??
    You should only add chemicals if you have a way to circulate the water.
    If you open while the water is still in the 50s, the likelihood of algae is lower. You should always close and open with the water in the 50s.
    Smykowski's Avatar
    Sep 2011
    3,065
    I did exactly that last spring, but like blizzle said, it has to circulate. I hooked up all my plumbing first.
