Thread: Plumbing planning
    Sep 2013
    Nashville, TN
    379
    Plumbing planning
    I'm trying to determine plumbing layout and requirements, please help
    There will be 3 returns down 1 side of the pool, should they all be individual 2" runs to the pump pad?
    2 steps jets in the steps at both ends, can each pair be tied together and ran 2' back to pad?
    2 Skimmers opposite side of returns, 2"run each back to pad?
    2 deck jets, thinking these both need to run all the way back so we can adjust if needed? 1 1/2" or 2"?
    Planning on using Savi Melody lights, looks like they need 1 1/2" run each back to pad.
    Anyway to guess on how much piping and fittings are needed?
    18x36 Vinyl, sports depth, 8' Roman steps at each end. Hayward 1.5hp 2speed pump, catridge filter, 2 skimmers, no main drain, 3 SR Smith Treo LED lights
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Plumbing planning
    What size pool are we talking about? Note there have been some reliability concerns posted about the Savi brand lights, I would suggest searching on the topic.
    Ike
    Sep 2013
    Nashville, TN
    379
    Pool size is 18x36 sports depth with 8' steps at each end, 1 1/2hp 2speed pump, SWG, catridge filter
    Sep 2013
    Nashville, TN
    379
    Seems like the Jandy nicheless and Globrites have poor reviews as well
    Aug 2011
    Middle TN
    83
    I don't really have anything to add but just wondered if you've started your build?
    18 x 36 Vinyl Inground, Coverstar Cover, 2 speed Pentair Pump, Hayward 425 Sq Ft Cartridge Filter, Hayward Heat Pump, Prologic PS8, T-15 Salt Cell, 2 Colorlogic LED lights, TF-100 Test Kit
    Sep 2013
    Nashville, TN
    379
    Plan is to be digging by the end of the month
