Thread: replumb my pump/filter
    May 2008
    Long Island, NY
    151
    I purchased a CricuPool Si45 SWG (to replace my liquidator) and a Ecotech EZ 1.5 hp motor. My existing equipment pad is very compact.
    I do not have enough room to pipe the flow switch and cell. I was thinking of installing the cell vertical. I plan on running 2" PVC from the multi-port valve to the Jandy valve for my cleaner.
    I am going to wait until the motor comes in to see if I have enough space under the multi-port valve. If there isn't enough room, I will rotate the filter 90 degrees and replumb the pump discharge also.
    I have an opportunity to move the pump/filter base back to get more straight pipe on the suction side of the pump. Is it needed?
    Am I missing anything else?
    Is it worth the investment to install a flowmeter?
    Pool Details: 25,440 Gal IG Vinyl 21x40 Mountain Pond (Graphex)
    Filter: Hayward Micro-Clear DE (48 Sq Ft)
    Pump: Hayward SP2603VSP VS Super Pump
    SWG: Circupool Si45
    Cleaner: Pentair Kreepy Krauly Prowler 820
    38,305
    Re: replumb my pump/filter
    I assume you saw this recent thread? Might offer some ideas:
    http://www.troublefreepool.com/threa...Circupool-si45
    If your current pump is not having any problems with the shorter suction line, then it should be fine.
    A flow meter is a "nice to have" but in no way needed. I am going to install one of the FlowVis this weekend, but I need check valves for my solar, so it does not really add much head loss. I would not recommend any of the other types of flow meters though.
    May 2008
    Long Island, NY
    151
    I saw the thread. I would have done the piping in 2" vs 1.5" to reduce friction loss. I am not going to do anything until the motor comes in.
    I like 2% FlowViz accuracy vs the 10% of a blue white and rotochem.
    SWG: Circupool Si45
    May 2008
    Long Island, NY
    151
    My , motor was delivered Friday. I got it installed today and it is too high and interferes with the multiport valve. Tomorrow, I am going to rotate the filter 90 degrees and repipe the pump discharge and the multiport line to the Jandy valve.
    SWG: Circupool Si45
    May 2008
    Long Island, NY
    151
    I am done plumbing. Now I just need to install a gauge in the discharge line, bond the motor and the SWG controller.
    I don't know why the lines coming out of the multiport valve are not parallel to the ground.
    SWG: Circupool Si45
