Thread: CYA
    DONNIE's Avatar
    Mar 2007
    OKLAHOMA
    122
    CYA
    Is CYA CYA or are there differences in sterength? Leslies is anywhere from $6.00 to $8.00 per pound and now I find this on Amazon at $2.80 a pound with free shipping and no tax. Any thoughts?
    Donnie
    http://www.amazon.com/Stabilizer-Cya...pr_product_top
    8500 Gallon Fiberglass IG / Sta-Rite pump,cartridge filter & heater / PoolPilot Dig 220-36 SWG / Testing w/K2006
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,112
    Re: CYA
    Cya is cya......but are you ever going to need 26lbs?? Unless you plan on using this for severallllllll months, a smaller container will cost more per pound, but save you in the long run as odds say you'll never use all that container.
    38,539
    Re: CYA
    If you were starting from scratch, you would only need 5 pounds in your 8500 gallon pool to raise it from 0 to 70ppm for your SWG. Assuming it does not all disappear over the winter, you might need to bump it by 20ppm every year which is 1.5 pounds.
    So a 26 pound container would last you about 15 years at that rate ... seems a bit excessive
