Thread: No recirculate option on my DE filter set up...
    deweypip's Avatar
    Jan 2012
    Richland, PA
    115
    Looking to get a handle on my green pool as stated in other post in this forum. Question--since I need to have water moving to get decent #s to base additions of various chemicals, is it advisable to just push water through my pump itself with no filter in place. Will I compromise my pump with no filter in place? There is an internal basket on the pump to catch any larger debris, algea should go right thru it. Any opinions out there???
    24x54 Sharkline Matrix
    Hayward 1 hp Powermax single speed pump
    Hayward ec50ac DE filter
    38,274
    Re: No recirculate option on my DE filter set up...
    The filter is after the pump ... so not having a filter would have no impact on the pump. The same water goes through the pump whether or not there is a filter after it.
    Are you just trying to do this so you have water movement when you are not around to backwash/clean the filter?
    deweypip's Avatar
    Jan 2012
    Richland, PA
    115
    you're right--i feel dumb now that i asked that question. I wish I could blame it on Monday, but it's Tuesday.
    Exactly, I just want to circulate water so I can get accurate values with cya, fc, ect as well as disperse chemicals. Everything need to clear out my algea problem.
    38,274
    No problem ... the obvious slips by all of us at some point
