Results 1 to 7 of 7
Thread: What to avoid with a fiberglass pool
    bear31088's Avatar
    Dec 2013
    Warner Robins, GA
    46
    I had a fiberglass pool put inlast year and the guy who installed it told me to NEVER use bleach in the pool. Don't know why. So....I come to this site and get all this great information with which I can keep my pool in pristine condition...and it's easy to use the TFP system.
    My questions are: Should I be using liquid chlorine? Isn't that bleach? And, with a fiberglass pool, are there chemical [B]imbalances [B] that I should avoid so as to not ruin the fiberglass?
    Latest chem readings:
    FC: 3
    CC: 0
    Ph: 7.6
    TA: 80
    CH: 230
    Thank you.
    Barry
    Barry, Central GA
    15X36 IG 14,200 gal fiberglass pool. Hayward Sand Filter with 1 HP Hayward SUPER PUMP. Pentaire "Kreepy Krawly Robotic Cleaner
    e-mail: oso49@cox.net
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Barry the guy who told you you can't use liquid chlorine ( bleach ) is wrong. Bleach is liquid chlorine.
    You missed the CYA test. Do you know what your CYA level is ? 😎
    Jeff
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: What to avoid with a fiberglass pool
    He is absolutely wrong. Chlorine is Chlorine. The fiberglass has no idea whether it came from a liquid, solid, or powder. The person telling you that simply does not understand. There is positively no downside or danger to adding Bleach/liquid Chlorine to a FG pool.
    Essential Links:
    The anti-bleach attitude is one of those rare pool myths that doesn't have even a small glimmer of truth to it. It goes back a long way. It used to be a lot more common, but is starting to fade out just a little these days. The origins come down to using bleach means not buying as much from the pool person, which is bad for them, so it must *obviously* be bad for you as well. From there they make up reasons why it is bad, which get passed down generation after generation till everyone forgets that they made it up in the first place.
    bear31088's Avatar
    Dec 2013
    Warner Robins, GA
    46
    Thanks all for the reassurance on using bleach/loquid chlorine. And sorry about leaving out the CYA value. It was 40.
    Barry, Central GA
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Your FC level is at the bare min for your CYA level. I would target 7 and that would give you some wiggle room for FC loss so you don't fall below your min. 😎
    Jeff
    bear31088's Avatar
    Dec 2013
    Warner Robins, GA
    46
    Thanks for the recommendation. I'll test again after work and balance accordingly. Thanks again.
    Barry, Central GA
