Thread: hydrochloric acid
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    hydrochloric acid
    all of my local pool shops sell hydrochloric acid as pool acid and have not heard of muratic acid
    Dr Google seems to think they are mostly the same
    besides strength are they the same?
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: hydrochloric acid
    They are precisely the same thing.
    Essential Links:
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    what brushpup says. They are exactly the same thing.
    Divin Dave,
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    In the UK, it is sometimes call "spirits of salts".
