Thread: Tiled fiber glass pool leaking at returns
    Masspools's Avatar
    Jan 2013
    Cambridge Massachusetts
    35
    Hi All
    I installed new return jets in a fiberglass pool that has been tiled. We placed the return jets on top of the tile with a gasket and silicon around the borders of the jet face plate. The jet face plate has threads that screw into the fitting in the back, sandwiching the gasket and the tile. We have some leaking and I am not sure if it is the threads. Has anyone installed return jets over tile, what would be the solution to fixing this problem, Silicon on the inside of the threads?
    Thanks
    James
    Masspools's Avatar
    Jan 2013
    35
    Re: Tiled fiber glass pool leaking at returns
    Solution:
    Originally, we used silicone on the gasket to provide a better seal. The silicone reacted with the rubber gasket and melted it causing the leaking around the fitting. We put the gasket directly onto the tile, and placed a thin layer of silicone around the outside of the fitting face plate. Also, we Teflon tape the fitting threads and it seems to have solved our mystery.
