Thread: Ok to leave robot in the pool?
    Strictly from a product longevity concern, is it ok to leave a robotic cleaner in the pool 24/7, removing only when closing for the winter?
    mbar's Avatar
    Ashland PA
    257
    Re: Ok to leave robot in the pool?
    I was told by the company to take the aquabot out after each use - the prolonged chlorine exposure can cause the belts to get brittle, therefore needing to be replaced more often.
    16x33 fiberglass pool sand filter
    you should always take it out
    Thanks fellas
    Mar 2008
    Central VA
    328
    I take mine out asap after running it; I always understood that if you added chemicals to the pool and you weren't supposed to get in, neither should your robot be in.
    Plus, after doing some light maintenance with the tires, o-rings, etc. it looks like alot of parts could get brittle with the chlorine and other chemicals.
    Todd
    Pool: 16x36, 16,800 gal., vinyl, sand filter, SWG & AquaCal Heat Pump
    Spa: Hot Springs Sovereign, 355 gal., ozone/ion
    The most helpful tool you'll ever have for your pool:
    http://www.poolcalculator.com/
