Results 1 to 15 of 15
Thread: Pentair Dynamo 1.5 hp Pump Leak
    Mar 2014
    Central AL
    59
    My 1.5 hp Dynamo pump is leaking where the pot mounts to the pump housing when the pump is off. The picture below shows where it is leaking. What holds the pot into the pump housing? The pot looks like it is sagging a little. Is there a way to tighten it from inside the pump housing. I have a new o-ring for the pot to housing joint and also for the pump housing to backplate.
    Russ
    33' diameter, 25,000 gal Above Ground Pool
    Pentair Dynamo 1.0 hp, 2 speed pump (#340204)
    Pentair Sand Dollar 60 filter
    22,542
    Re: Pentair Dynamo 1.5 hp Pump Leak
    That's a threaded connection with an o-ring seal. Take it apart and replace the o-ring and be sure lube it when putting it back together.
    Mar 2014
    Central AL
    59
    Does the entire pot thread into the pump housing or is there a nut inside the housing that tightens the pot to the housing?
    Russ
    Willi's Avatar
    Mar 2014
    Florence, KY
    69
    Quote Originally Posted by RussH View Post
    Russ
    No nut, just threads in
    18' x 36' IG Vinyl 30K gallon, Hayward 1 1/2 HP pump and DE Filter hardpiped, Aqua Pro 1300 Electric Heat Pump.
    TF100 Test Kit on order !
    Commercial Popcorn machine, sno cone machine and cotton candy machine, lost my red nose.
    22,542
    As Willi said, it just threads into the front of the casing.
    Mar 2014
    Central AL
    59
    It seems like it could be hard to get it to seal. What do you do if it tightens up before the pot is in the upright position? Back it off? Wont it leak?
    Russ
    The compression of the o-ring should give you enough of a range of rotation that seals that you can get it vertical without a problem.
    Mar 2014
    Central AL
    59
    This pump is pretty well used up. The bearings are noisy on a cold start, I have had to replace the power cord due to damage and today the power switch lever broke off when I turned the pump on. Fortunately it broke in the on position, but cant turn it off without killing it at the breaker. I am not wanting to spend a lot on a replacement. A Pentair 1.5 hp like it or a 3/4 hp are about the same price. Would I likely regret stepping down to 3/4 hp? I get the feeling it makes too much flow now. The only thing I can think of that would be impacted would be vacuuming.
    Russ
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Unless you get tons of leaves a 3/4 hp will do a decent job vacuuming. Have you looked into the 1 hp 2 speed pump? I have one that I run on low for everyday filtering and high for vacuuming.
    Love TFP? Become a
    TFP Supporter!
    Mar 2014
    Central AL
    59
    I had looked at the 3/4 hp 2 speed, but the 1 hp 2 speed may be a better choice.
    Everything I've seen says that it ships without a power cord. The cord I got as a replacement was a Pentair number 79137800 3 ft standard cord assembly. Any idea if that will work with the 1 hp, 2 speed pump?
    Does the pump have an off switch at the pump like the 1.5 hp single speed?
    Russ
    22,542
    If you can tell us the model number of the pump you're looking at we can most likely tell you if it comes with a cord and/or switch.
    Mar 2014
    Central AL
    59
    The pump I am looking at is a Pentair #340204.
    Russ
    22,542
    I believe that the model you listed does come with a cord and switch. At least the ones I've seen have.
    Mar 2014
    Central AL
    59
    Pentair's web site says it doesnt come with a cord, so I called Pentair and they say it doesnt come with a cord or a switch.
    So, I would have to wire it. All I have at the pool is a 110V GFI outlet in some form of weatherproof box. I also have an Intermatic P1103FE timer in the circuit inside the house. I can put a GFI breaker in the breaker box for the circuit and put whatever type switch is required to operate the pump in the weatherproof box at the pool. I still need a way to turn the pump off at the pump for maintenance.
    What kind of wiring connectors does the pump have on it? Spade connectors? Pigtails?
    Here's the 110V outlet. I cant find and brand or model numbers on it. Is there a way to mount a standard light type switch in it? Would this Leviton 1286 be the correct switch type?
    http://www.leviton.com/OA_HTML/Produ...minisite=10251
    Russ
    Mar 2014
    Central AL
    59
    For the record, the 340204 pump came with a switch but no cord. I'll move the new cord I got for the current pump to it for now.
    Russ
