Thread: Melamin to reduce CYA
    Mar 2014
    Germany
    10
    Hey pv5490,
    don't know if I can help you? It's possible to remove CYA by using melamin. Melamin is a powder which is mixed with hot (!) water and poured into the pool. Melamin absorbs CYA and can be filtered out of the water (similar to flocking-products). The amount of Melamin being needed is depending on the CYA level. Melamin is absolutely harmless.
    http://www.carlroth.com/catalogue/ca...e-de&market=DE
    Try to search google.
    Wikipedia:
    http://en.wikipedia.org/wiki/Melamine
    Ciao, Marcus
    23.000 liters round inground Pool, 50 kg. sand-filter with crushed glas filter medium (0,5-1 mm.), 5 OKU sun collectors, calcium-hypochlorit pellets, 0 ppm. CYA
    38,262
    Re: Problems with algae and milky water HELP
    Quote Originally Posted by Natatoria View Post
    Hey pv5490,
    don't know if I can help you? It's possible to remove CYA by using melamin. Melamin is a powder which is mixed with water and poured into the pool. Melamin absorbs CYA and can be filtered out of the water (similar to flocking-products). The amount of Melamin being needed is depending on the CYA level. Melamin is absolutely harmless.
    Ciao, Marcus
    If it was that easy ... we would all be doing it. There are numerous discussions about this in the forum:
    https://www.google.com/search?sitese...=0&safe=images
    This one pretty much sums it up:
    http://www.troublefreepool.com/threa...YA-precipitant
    Mar 2014
    Germany
    10
    Thanks for the information, I never used melamin, but I heard it works
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    After reading these threads I wouldn't dare try it. Sounds like a true cloudy pool nightmare.
    Essential Links:
