Results 1 to 17 of 17
Thread: This is how a pool should open!
    Feb 2012
    Maryland
    400
    Opened the pool on Friday, water temp is 47! My arm was numb taking the return winter plugs out and putting the fittings back in, but it was worth it to finally see my pool again!
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    Jul 2012
    Herndon, VA
    419
    Re: This is how a pool should open!
    Why are you opening already if you're in MD?
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    Feb 2012
    Maryland
    400
    Quote Originally Posted by GuinnessPhish View Post
    Multitude of reasons. Top 3 are.
    1. To beat the algae. Its a mesh cover.
    2. Like the look of the pool rather than a winter cover.
    3. Doing patio work and needed the cover off to put the bullnose pavers around the pool.
    Willi's Avatar
    Mar 2014
    Florence, KY
    69
    Gumby, I'm with you...cant stand looking at the pool cover but wifey keeps me in check and wont let me open till first week of May.
    18' x 36' IG Vinyl 30K gallon, Hayward 1 1/2 HP pump and DE Filter hardpiped, Aqua Pro 1300 Electric Heat Pump.
    TF100 Test Kit on order !
    Commercial Popcorn machine, sno cone machine and cotton candy machine, lost my red nose.
    Smykowski's Avatar
    Sep 2011
    3,065
    Mine's still a block of ice in Chicago, but I'm starting the process as soon as it's thawed for gumby's reasons 1 & 2.
    38,246
    Quote Originally Posted by Willi View Post
    Well, your opening should not be a function of calendar date. It should be a function of water temperature. We recommend opening while the water is still in the 50s to make your life easier. As you can see, ssgumby opened to a nice clear pool ... which may not be the case if you wait too long.
    Willi's Avatar
    Mar 2014
    Florence, KY
    69
    Our water is usually in the 50's about the first of May.
    I also have an open mesh safety cover on the pool and the water turns dark green not long after I close it.
    BUT, I would much rather open sooner, especially now that I just received my TF-100 kit over the weekend and want to play with it
    38,246
    Are you closing following our methods when the water is below 60 degrees? I have no experience with this, but I do think it is harder to keep a clear pool with a mesh cover.
    Willi's Avatar
    Mar 2014
    Florence, KY
    69
    When I had my AG my pool was clear every spring, the open mesh on my IG is another story.
    New to IG's when we bought our house 4 years ago the previous owner suggested to contract out the closing so thats what I have done since. I do everything else including opening.
    I had been looking for a forum to understand pool chemistry better and save a few bucks because I felt I was spending more money than I needed to be. Learning to close will be a bonus.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Closing when the water temp is 50 or below and bringing your FC up to SLAM level for your CYA level will go along way to opening to clear water.
    That said you need to open when your water temp is in the same range. Even if you leave the cover on, it's good idea to get the water moving and adjust your levels. 😎
    Jeff
    Willi's Avatar
    Mar 2014
    Florence, KY
    69
    Quote Originally Posted by pwrstrk View Post
    Even if you leave the cover on, it's good idea to get the water moving and adjust your levels. 
    Would be hard to do that since the cover is tight and buckled down to the anchors and plugs are in all the discharge jets. Not sure I could loosen the sides of the cover and remove the plugs. But it does make sense and I imagine would make the opening a little easier.
    It usually takes me a week to get it clear.
    Sorry for hijacking your thread Gumby
    Feb 2012
    Maryland
    400
    No worries Willi.
    I didnt close my pool until first weekend in November, so water was in low 50's when I closed. I did not SLAM or add a single thing, I simply winterized late and opened early to a clear pool with the exception of some fine dirt that makes its way through the mesh.
    Sep 2009
    Frederick County, MD
    184
    In MD as well. Looking to open in the next week or so.
    Close when it is cold, open when it is cold = no problems for me.
    Jim
    Southern Frederick County, MD - Leisure Moroccan 38 Fiberglass Pool - 19,800 gallons
    Pentair 1.5 hp 2 speed pump - Cartridge filter - Dolphin robot - TF-100 Test Kit - SWCG
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    I dare you to swim in it.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    Feb 2012
    Maryland
    400
    Quote Originally Posted by sargent View Post
    Funny you say that. Was reading an article on some sore muscles. Soaking for 10 mins in 50 degree ice water is suppose to relieve the muscle soreness. NFL players soak day after each game. Having said that, I am not an NFL player and I would rather have sore muscles!
    P.S. sore muscles from patio construction!
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    I'm getting anxious to open my pool as well but I live in Michigan the land of eternal coldness. I might still open it in a week I have in years past.
    16 x 32 Inground Vinyl 21000, 2 returns, 1 skimmer, 1 main drain. Raypak Heater, Crystal Flo Sand Filter
    Jul 2013
    Swartz Creek, MI
    67
    Not open yet but my cover tore so I can see my water is still pretty clean and clear!!
    45ish year old, 16x32, 19,000, IG, Concrete/Fiberglass Hybrid in need of restoration
    Sand filter with 3/4 hp AO Smith pump. 1 skimmer, 1 main drain, 1 return
