Thread: Hard plumbing question
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    As many of you know, I've been slowly converting my small pool to hard plumbing.
    I've been doing some reading on this subject, and have come across the idea of a complete loop around the pool especially for the returns. I think I understand the principle behind this, that being easier to balance flow rate through multiple returns/. I am wondering if it would be worth doing to mine.
    So far I have two returns, and one skimmer. I'm planning on adding a couple more returns, plus a low mounted suction port in addition to the dedicated vacuum port.
    The question is, will this improve the overall operation of the pool?
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: Hard plumbing question
    I wouldn't bother. The larger the loop, the less impact it has. They work well for spas but less so for pools. Also, having equal flow out of the returns isn't really necessary and I doubt it would have a material impact on the operation of the pool.
    Mark
    30,432
    I wouldn't bother, either, but you could "test" it a bit with using smaller eyeballs at the returns closest to the pump.......I doubt you will notice much difference and I can't see it being much more efficient.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Thanks, guys!
    I appreciate the input. That kinda follows what I thought.
    mas985's Avatar
    Pleasanton, CA
    11,743
    While that would help to equalize flow rate, it would make the exit velocity imbalance higher. I might be more inclined to do the opposite. Putting the smaller eyeball on the furthest return would help equalize exit velocity at the expense of flow rate equalization. Exit velocity is what does the "work" of the return and helps move the surface water as well as helps mix the water. Of course if you have a choice, you could just arrange the returns to be equidistant from the equipment.
    Mark
