Results 1 to 12 of 12
Thread: SWCG readout much lower than testers show
    Carrollton, TX
    126
    Just fired up the Aqua Rite turbo cell and set it to 50%. PB added salt 3 weeks ago. Last week, readings were 3800; Monday it was 3700 - took 2 samples to 2 different Leslies and PB checked it Monday - he used a Goldline electronic tester. Leslies used electronic testors too with the digital readout.
    Readout on the Aqua Logic keypad said salt at 2800ppm. Why so much difference?
    7000 gallon IG freeform w/ 6 ft. spa, 21 ft weeping wall, Hayward SP4020NS Northstar pump, Colorlogic LED’s, DE6020 filter and H400IDL2 400,000btu heater. Aqua logic 8 zone controller with Aqua Rite salt chlorine generator, Stonescapes pebble finish – Aqua Blue and flagstone coping, stamped/stained concrete deck
    Some SWG estimate salt levels based on conductivity of the water. If your water is fairly cold the conductivity will be lower than usual so the unit can read lower than the actual salt level. If your water is in the 80s then it is more likely that it has gotten out of calibration.
    DONNIE's Avatar
    Mar 2007
    OKLAHOMA
    122
    Get a Taylor salt test kit. It's the easiest and most accurate way to get the correct reading. I don't know about your unit but I was able to calibrate my Auto Pilot to my results and it's been perfect ever since.
    Donnie
    8500 Gallon Fiberglass IG / Sta-Rite pump,cartridge filter & heater / PoolPilot Dig 220-36 SWG / Testing w/K2006
    Carrollton, TX
    126
    Thanks for the responses. Pool water is 79 degrees so that may be part of it. I don't know if I can calibrate the Goldline unit - I will check out the instruction manual to see if I missed something. It did show 2900 this morning. Ordered a test kit with salt tester from Dave and it is in transit.
    mas985's Avatar
    Pleasanton, CA
    11,737
    You mentioned AquaLogic as well as the AquaRite so I am not sure which you have but I can speak to the Aqualogic unit. My unit reads the same salt level no matter what the water temp is. This spring I went from 55 degrees to 90 degrees without any change in the salt level reading (2900 ppm). However, I noticed a large change in the current draw which I should since conductivity is fairly dependent on water temperature.
    The Aqualogic compenstates the salt reading for temperature and this is why it remains constant. Otherwise the salt reading would have gone up with temperature.
    What I do not know is if the Aquarite unit does the same but I would be surprised if it didn't.
    Mark
    Carrollton, TX
    126
    Mark, sorry for the confusion. I have the Aqua Logic PS8 controller. The salt cell is labeled Aqua Rite and plugs into the Aqua Logic board. Salt readout now shows 3000. Maybe it's just taking a while to get the measurement?
    Mark C
    mas985's Avatar
    Pleasanton, CA
    11,737
    The Aqualogic unit has two different salt readings. The one you normally see is in the default menu and is a long term average reading. Not sure how long though.
    The diagnostics menu has an instant salt reading and represents a more current reading of salt levels. By pressing the + button on the instant salt reading, you can recalibrate the unit and the average salt reading gets updated. Give that a try and see if it is any better.
    If that doesn't help then inspect the cell to make sure you don't have any calcium build up. That will throw the reading off as well.
    Mark
    Ft Lauderdale, Florida
    1,455
    Aqualogic is the controller. Aquarite is the salt system. Both owned by Hayward.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Carrollton, TX
    126
    Mark, thanks for that info! I did what you suggested and now the salt shows 3200. I can verify when I get the test kit from Dave. Should be here Monday or Tuesday.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by Poolsean
    Actually, that's not quite right. Aqualogic is a controller and a salt system together in one unit, you just add the cell for a SWG. Aquarite is a salt system only without the controller.
    I was a bit surprised that he said his cell has Aquarite label on it as mine does not. Mine simply says Turbo Cell T-15. I thought the cells were the same but perhaps not.
    Mark
    Carrollton, TX
    126
    Mark, after actually paying attention to the label itself rather than the instructions, the cell says "Aqua Collection" Turbo cell T-15. Does yours have the Aqua Collection label?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Mine has the same label.
    Also, be aware that I have received bad test results from pool stores. The problem with electronic meters is they need to be calibrated once in a while. Also, to get an accurate reading, they must compenstate for water temp which many do not bother to do.
    If you added the right amount of salt to the pool per the instructions, then I would tend to believe the Aqualogic reading rather than the pool store readings since this is closer to what it should be.
    The test kit will be the most accurate measurement.
    Mark
