Thread: Paramount 6 Port Module Impeller Stuck
    Mar 2013
    New Mexico
    4
    Just fired everything up today and the Paramount impeller won't turn on the 6 port. It looks like the impeller shaft is almost seized in the housing. I can force it to turn a little bit. I should have lubed it before winter storage. Has anybody broken these down for repair?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Paramount 6 Port Module Impeller Stuck
    Can you post a picture? I'm not too familiar with the Paramount systems, but I imagine it should come apart fairly easily.
