Results 1 to 7 of 7
Thread: Don't Foret to Clean the Filters........
    iggy's Avatar
    Jan 2008
    The Cool Part of Arizona
    175
    Hi All,
    It has been about 5 months since my pool was finished and I wanted to give others my perspective on what I have seen and learned about my pool.
    I have a nice 4 cartridge Jandy filter CL460. I have cleaned it today which makes it the 3rd cleaning (Jan Apr, Jun). My water pressure wasn't high (about 12 psi) but I still felt I better clean them before it gets hotter. To my surprise they were dirty and I must have removed about 10 lbs of just air pollution as we call it here in Arizona. Lots of small particles of ground dust/dirt. I washed everything down and cleaned and inspected all the gaskets. Cleaned my in-floor valve controller and decided to remove my Chlorine Cell just to see what ups. I had no visable deposits so I just reinstalled it. Everything back to gether and my PSI is down to 10 psi which it is normally.
    My infloor cleaning system saves a lot of time with a typical cleaned. I still have to sweep a few times a week but the dragging in and out of the floor sweeper and possible deterioration I'm still glad I have the in-floor system.
    Things that I like about my pool. Definitely glad I got a water fall. I'm glad I got 4 return lines hooked up together. Glas I got the SWG, larger filter and 1 1 /2 hp moter.
    Chemicals purchases
    Muratic Acid (7 gal), water claifier to clump the dust to the filters.
    Todays Water Chemistry a few times a week.
    Especially Chlorine, pH and Alk.
    FC 5
    TC 5
    Ph 7.6
    Alk 80
    Hardness 250
    CYA actually it is around 80 but fluctuates by pool store 50 to 100
    Water Temp 90
    Chlorine Genrerator 33%, Pump runs 5 hrs a day so far. May have to increase more soon.
    So back to my subject line.......
    Don't forget to clean your filters when you get the chance.
    I figure it is a very important part of my whole pleasurable pool experience.
    HAVE A GREAT 4th of JULY HOLIDAY and don't forget to fly our flag high.
    In-Ground SWG pool 11,000 gal., Jandy CL460 Filter, 1.5hp Stealth Jandy pump, Paramount PV3 In-Floor cleaning sys., Goldline SWG, Hayward Color Logic 2.5 LED Light
    ktdave's Avatar
    Katy, TX
    888
    Re: Don't Foret to Clean the Filters........
    Iggy,
    Thanks for the great info on what you have experienced since your pool has been in operation!
    One thing I noticed that may be of help to you is that your CYA level of 50 is a little low for your SWG. Goldline suggests a CYA level of 60 - 80 and says 80 ppm "is best".
    Happy 4th to you too! and glad you're having a great experience with your new pool!
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    iggy's Avatar
    Jan 2008
    175
    Quote Originally Posted by ktdave
    Iggy,
    Thanks for the update. It actually is 100 but I put in the low that the pool stores have come up with. Some days they say 100 and some days they say 80 then 50 then back up to 100. I know for sure it is between 80-100 which may be high but here in Arizona we need it high because of the sun and heat. I guess. I will change it to 80 in my message.
    Jul 2007
    Suwanee, GA
    528
    Iggy,
    I have the CL460 as well and I cleaned them this past month for the first time since the pool was finished, which is about 10 months now. My pressure has always been low, I believe I only gained about 2psi since installed. But they were very dirty, it took me about 30 minutes each to get them clean and all the mud was on me when I was done. What a PITA that was. I found it best to use a non-pressure regulated hose that I plumbed from my sprinkler system. I'd still be cleaning them w/o it.
    I do need to find a better hose attachment. I used one with a flat sprayer, but it did not let enough water volume through.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    iggy's Avatar
    Jan 2008
    175
    Quote Originally Posted by crabboy
    Iggy,
    I have a large plastic tub (probably 20 gal) I use to wash each filter in. I systematically start at the top 1/4 and work around until I see clear water then work down to the next 1/4 and do the same all the way to the bottom. When I reinstall filters I flip them 180 degrees. That way I have even deterioration on the bottom edges which collects the most dirt. Also I can dump the dirty water around the plants when the tub gets full. Here in Arizona we learn to use water wisely. 8)
    Have a great 4th.
    Guest
    Read this:
    how-to-clean-a-cartridge-filter-t4465.html
    iggy's Avatar
    Jan 2008
    175
    Quote Originally Posted by waterbear
    Read this:
    Thanks waterbear for the link to the sticky.
    This website has so much to offer everyone.
    Have a great 4th!
