Thread: polymeric sand on gunite
    TS's Avatar
    Jan 2014
    Las Vegas, NV
    3
    Angry polymeric sand on gunite
    The guys installing our pavers got a bunch of activated polymeric sand in the pool on top of the gunite. It's stuck there pretty good at this point. The mini pebble tec was supposed to be put on next week. Does anyone know if the stuck on polymeric sand will cause a major problem with the pebble finish sticking correctly to the gunite?
    Thanks.
    under construction
    38'x20' 19K gal, IG gunite, 7'x7' spa, Pentair variable speed pump, 420 sqft cartridge filter, 400K btu heater, Pebble Sheen finish
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: polymeric sand on gunite
    I don't know, but this is a question the installer needs to answer. Sorry to be of no more help, but you really need a professional opinion.
    Essential Links:
